Old 04-21-2021, 10:30 AM   #1
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Question What does your home tool setup look like?
I am looking at buying a rolling automotive tool box and a new set of sockets with wrenches. In addition, I found a couple nice electric impact guns to grab too.
Does anyone have suggestions for a mid-range rolling toolbox and a good socket set/wrench set? Other than the typical extensions, are there any specialty adapters to look for when working on these engines (without pulling it)?
If you have pics, please post them for ideas!!
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 04-21-2021, 10:55 AM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I've got a 170 piece fatmax set I got on clearance locally. Any kit of this size or larger is a perfect base kit. I've had mine for years with no issues.
I've accumulated a bunch of other stuff from Canadian tire as they sell their mastercraft brand often at 40-70% off and it's actually decent quality. Wracheting wrenches, 70 piece screwdriver set, wrench/plier set, etc
The only specialty tools I've needed were flare nut wrench for Bleeder screws and a passthrough wrachet set for struts and getting sway bar end links off. Generic "specialty" tools not specific to this car.
I don't have a proper tool box, but have been fine with a mac tool bag. I can chuck everything I have into it including the cases for all of the impact sockets, drill etc and carry the base kit case and take it with me.
Similar to this one, though mine is bigger. I'm guessing they don't sell it anymore.
https://www.mactools.ca/en-ca/Tool-S.../Wheel-Pro-Bag
The Following User Says Thank You to RToyo86 For This Useful Post:
BrahmaBull1990 (04-21-2021)
Old 04-21-2021, 11:04 AM   #3
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Yes! This is exactly the type of set I am looking for. How much did all this cost you?
Old 04-21-2021, 11:28 AM   #4
RToyo86
RToyo86's Avatar
I'd have to tally everything up. In sales I've probably saved a good $700+CAD.
I'm not factoring in taxes just list prices. Probably spent about $500-600 in tools if I had to round.
I think the tool kit was 400-500 regular I got it for 179.
Screwdriver set was 80 on sale for 20.
Wracheting wrench set was 200 on sale for 80.
Impact set 130 on sale for about 50.
Wobble extension set was in the 30 range paid.
Breaker bar was also cheap around 20.
Passthrough set was $60 via Amazon.
Adjustable wrench and plier set was 70 on sale for 30
Flare nut set I got 10 years ago. Can't recall the price but less than $60.
Plug in impact drill was 80 10 years ago. I'd buy cordless now.
I was fortunate to inherit the tool bag and torque wrench. Add $300-400 for those depending on what you get. Probably some odds and ends I am forgetting.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
BrahmaBull1990 (04-21-2021), Tcoat (04-22-2021)
Old 04-21-2021, 12:08 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Buy what you can afford at the start and then upgrade certain things as you go. I like nice ratchets, screw drivers, and a good set of combination wenches. Most other things I buy cheap. I would also recommend making sure you get a set of 6pt sockets. 12's are convenient, but when you get a stubborn fastener that is very tight a 6pt will save you a lot of grief.
I actually like to have multiple tool boxes. I keep hand tools in one box and power tools in another. I have 3 boxes total right now. Also a good idea is to buy those magnetic strips and machine screw them to the side of the box. That way if you are working low or on the ground you can stick the tools you are using to a spot you can reach them from a stool and not have to worry about kicking them around. This is not a bad little box, I have 1 for my hand tools. Also don't forget drawer liners.
https://www.homedepot.com/p/Husky-26...66BK/309580736
This cheap set from lowes is a good base. But you will want to add a full set of metric combination wrenches. Down the road maybe get some more screw drivers.
https://www.lowes.com/pd/Kobalt-138-...l-Set/50200791
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
BrahmaBull1990 (04-21-2021), soundman98 (04-21-2021)
Old 04-21-2021, 12:32 PM   #6
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Thank you. It looks like waiting for sales and accumulating tools over time is the way to go, unless you want to pay nosebleed prices
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
RToyo86 (04-21-2021)
Old 04-21-2021, 12:39 PM   #7
RToyo86
RToyo86's Avatar
Yep. A good base kit with a torque wrench and a breaker gets you through most stuff. I used the 3/8to 1/2 adapter to run the 6point 19mm deep socket for wheels in my set until I grabbed the 6 point 1/2 impact sockets.
I hardly use them for impact use but they're good to have
Then it's a matter of piecing everything else you want together. I bought the one off use stuff when needed in advance.
Old 04-21-2021, 01:43 PM   #8
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
I got the Husky Set from Home depot last year and is absolutely amazing. Any new part that has gone into the car has been installed using this set. Seems to be out of stock but it give you an idea what to look for.
https://www.homedepot.com/p/Husky-Me...0MTS/301653450
spcmafia is online now   Reply With Quote
The Following 2 Users Say Thank You to spcmafia For This Useful Post:
BrahmaBull1990 (04-21-2021), norcalpb (04-21-2021)
Old 04-21-2021, 02:11 PM   #9
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Husky isn't bad for the price! I have a few of their tools.
Has anyone tried the new line from Harbor Freight called Icon that is suppose to compete with Snap-on?
Old 04-21-2021, 02:54 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The difference I notice in cheap wrenches is how fat they are. Most of the time not an issue, but it can be in certain instances. I would not want to try removing the driveshaft bolts with those. I don't think they would fit.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Old 04-21-2021, 02:56 PM   #11
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Yep! And then you get stuck using a ratchet with 6 degrees of range because you have no hand clearance.
Old 04-21-2021, 03:03 PM   #12
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
True. But for general use, as you said, it will mostly not be an issue. I have a kit from Harbor Freight that has been getting everything I need done perfectly - and that's for under $100 for a full kit of tools.
Also went cheap on my first torque wrench, about $30-40 on Amazon and has been used for just about everything that requires proper torque up to about 120 ft-lbs on the car.
The way I see it from there is if I need a specific tool to do a job that my standard tools can't do, I go get a good quality one - having saved plenty of money on all the general tools.
Dzmitry is offline   Reply With Quote
The Following 2 Users Say Thank You to Dzmitry For This Useful Post:
BrahmaBull1990 (04-21-2021), NoHaveMSG (04-21-2021)
Old 04-21-2021, 03:08 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Another nice thing is that with cheap tools, no fear in modifying them. I have quite a few wrenches ground down or bent at odd angles for special use. I also have a bunch of sockets I have turned down in the lathe to shorten them or skinny them up.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
BrahmaBull1990 (04-21-2021), Dzmitry (04-22-2021), RToyo86 (04-21-2021), soundman98 (04-21-2021)
Old 04-21-2021, 03:32 PM   #14
RToyo86
RToyo86's Avatar
I want a basic welder for this reason. I'd happily weld a a throw away extension and socket together to get around the issue I ran into when installing the rear shocks the other week.
I picked one of few passthrough wrachet sets that didn't include the 3" extension
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 06:36 AM
WHAT WILL BE THE BEST TUNING TOOL FOR A NITROUS SETUP Zex_Frs Software Tuning 25 03-29-2015 04:52 PM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring NY / NJ / CT / PA 0 10-20-2014 10:48 AM
What does this tool use to carscat Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 06-27-2012 09:24 PM
