Drives: 2023 GR86
2020 Toyota 86 Apple Carplay Headunit
I believe this headunit has been produced for the 2020 GT models only. Would anyone know if the 2020 86 Apple Carplay Headunit would fit in a 2019 86 TRD SE?
Drives: 2020 Toyota 86 GT 6M
it's a shitty unit and you'll degrade your sound quality by swapping to it since it requires the amp to be bypassed but does not have enough juice to properly drive the oem door speakers so your sound will lack bass. Probably a better idea to look at aftermarket since you can probably get better units for cheaper than oem
| The Following User Says Thank You to saltywetman For This Useful Post: | Jasper (04-11-2021) |
#3 | |
Drives: 2023 GR86
#4 | |
I think the only way to truly "upgrade" the sound would be to manually wire an aftermarket amp that hooks up to you aftermarket headunit that will guarantee enough amplier output to sufficiently drive the oem speakers. Would be much more work since you'd have to custom run wires to your trunk unless you can somehow modify the oem harness that runs to the oem amp in the trunk to work with the new amp. |
#5 | |
Drives: 2023 GR86
i don't think i'd spend money on oem+ solution even if i had the money. has nice car specific subwoofer box to make it look more seamless in trunk but i doubt a bulk of their cost is spent on high quality speakers. Personally, i'd rather spend the oem+ money on higher end amps/speakers rather than custom fitted boxes. I haven't looked into aftermarket solutions myself but am eventually going to consider seeing if I can upgrade the headunit to a better one with a more powerful internal amp that can drive the door speakers so that the sound isn't so thin with the 2020 head unit.
Just grab Boss BE7ACP from Crutchfield, add there package to retain almost all stock functions and get there pre made wiring harness all for less than 400$ shipped. Its made for your 2019 Model car
2013 Series 10 FRS #553
| Tags |
| 86 headunit, android carplay, apple carplay, oem headunit |
| 2020 gets new HU w/ Android auto, carplay | RZNT4R | Electronics | Audio | NAV | Infotainment | 72 | 09-18-2020 12:09 PM |
| KY FS Alpine iLX-007 headunit Apple CarPlay | JDMBRZ | Audio/Visual, Electronics, Infotainment, NAV | 3 | 01-19-2020 08:52 PM |
| BRZ apple carplay skips/glitches | prizmracer | Electronics | Audio | NAV | Infotainment | 10 | 03-28-2019 03:21 PM |
| Apple CarPlay: iOS Vehicle Integration | mikeTee | Other Vehicles & General Automotive Discussions | 46 | 11-19-2014 01:43 AM |
| Apple iOS Carplay!!! | Visxco | Electronics | Audio | NAV | Infotainment | 28 | 07-06-2014 04:19 PM |
