Drives: 2016 Subaru BRZ Premium DGM (61K)
Sway Bar Upgrade on stock suspension
Hi guys,
I drive a 16 BRZ premium. I am considering upgrading my sway bars (probably to Whiteline or Eibach). I am on stock suspension for now but have upgraded to wider wheels and stickier tires. I love the added grip but it comes with more roll in corners. It feels like it is mostly in the front end but I could be wrong. Can I go for just a front sway bar to reduce this or will I need to do both to maintain the neutral handling it had before? And whichever way I go, what should I be looking out for? Thanks! |
Drives: 2017 BRZ Premium
Do you have plans to do further suspension upgrades in the future? (Coilovers, springs etc.) Typically sway bars are used to fine tune a suspension system once the springs and dampers have been selected. In your case, if the stock springs/dampers are the weapon of choice, you can certainly add 1 or both sway bars to the factory system and still see benefits. I would recommend a front bar 1st, this will offer better oversteer resistance and a noticeable front end stiffness increase. I ran a Whiteline front bar for several years on the stock suspension for autocross use and it made a considerable difference.
Drives: 2013 WRB BRZ
I'm on stock suspension with a front bar. Works for me!
Drives: Toyota 86
In my opinion, 22mm front and oem 2017+ 15mm rear bar is a great setup, especially if you don’t want to use a lot of front camber, I’ve had 20 16 on stock 2017+ setup (showa base shocks not sachs) and while I liked the front when I put the rear I didn’t like the balance of the car, even on the softer setup, but I think it’s also a matter of tastes
Drives: -
I went with a Perrin 22F 16R adjustable setup. I set the front to soft and rear to medium and the balance was preserved. Nice thing about adjustables is you can dial it in just the way you want it.
Persona Non Grata
Drives: '15 BRZ (WRB)
If you want to try a low impact experiment first, install poly sway bushings front and rear. I found it made a noticeable difference on my '15. Roll stiffness is increased and more linear. I plan to replace the struts/shocks with B6s combined with Pedders upper front mounts in the next year or so, but have no plans to track or AC the car, so that will probably end my suspension mods.
Slow is smooth, and smooth is fast
| The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post: | norcalpb (04-09-2021), Ohio Enthusiast (04-07-2021) |
Señor Member
I had the same experience. Changing the bushes to poly made a surprisingly noticeable change to feel and handling.
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | norcalpb (04-09-2021) |
#8 | |
2013 Series 10 FRS #553
Drives: 2017 BRZ PP, 2004 WRX
A lot of people run only front bars for autocross. This is for street class (one swaybar replacement allowed) and even street touring (both allowed).
In general, adding the larger front bar adds in keeping front camber in check, lessening tire rollover, and using the most grip from the front tires. Leaving the stock rear bar is typical, but an swap to a 2017+ bar is a cheap upgrade. In general, a 20mm front bar works for most people for autocross/track as well as street driving, with or without upgrading the spring/struts later. 22mm can work, but many times it's too much front bar for stock springs/struts, creating more understeer. If you're not autocrossing and sticking to some rules, also adding a front strut bar seems to slightly help with front stability too. Certainly not as much as a swaybar. For the price and 5 minute installation, I think they're worth it.
#10 |
I’ve played around with some bigger rear bars and I never liked the feel of them, especially for daily driving use.
I currently have whiteline bushings on my 14mm Oem rear bar and AVO bushings on my front 21mm TRD sway bar and I still get plenty of oversteer on the track. If I were you I’d just get the front bar. They come in sizes 18mm-25.4mm and which size you get should depend on how much you drive on the street and how much roughness you are ok dealing with. When I first bought my car in 2013, I got to do an autocross ride along with this guy named Manny in Arizona who only had a bigger front sway bar (Hotchkis 25.4mm) and sticky tires on his stock suspension. However his driving and the cars ability opened my eyes up to what this car can actually do, so I wouldn’t worry about ruining the cars balance by just going big front bar. If you find the car understeers with the big front bar, get camber bolts and add camber. Given that the front suspension is McPherson, stiff suspension components will help prevent camber loss, even though camber loss on these cars is not as crazy as say on a 2004 STi. |
| Sway bars for 2017 stock suspension | Menashe123 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 41 | 03-01-2018 09:12 PM |
| Track outer shoulder wear : sway bar upgrade? | 86league | Tracking / Autocross / HPDE / Drifting | 39 | 12-14-2017 11:00 PM |
| Suspension upgrade | Jmk91 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 09-14-2016 12:55 AM |
| My 2013 FR-S Suspension Upgrade | g0odspeed | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 11-21-2015 11:08 PM |
| Looking to upgrade rear sway bar, any suggestions? | Str8Ghostin | Tracking / Autocross / HPDE / Drifting | 8 | 02-22-2015 10:40 AM |
