Old 04-06-2021, 09:08 PM   #1
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Question EcuTek DTC but no CEL?
Hi All,
Just finished-up my final logs with Delicious and received my final tune. The car is running very well, but I periodically pop the DTCs: P0507 - idle air RPM higher than expected, and P015A: 02 Sensor Delayed Response - Rich to Lean Bank 1 Sensor 1.
I have a Tomei UEL catless header, Tomei overpipe, stock front pipe, and Corsa catback.
These codes come and go but I have not had a CEL from them yet and the car idles and drives fine. I’ve mentioned it to Delicious when I send my logs but they never mention it when they reply with my updated tune.
Is it safe to ignore these since it is not triggering a CEL and the car is running fine, or should I contact Delicious about them? The car has 6k miles, so
I do not want to cause any early issues.
I’ll add too that my LTFT and STFT are fine and LTFT is -3% at most and I have not seen it positive/indicating lean (as the O2 sensor DTC implies)
Thank you
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 04-06-2021, 09:15 PM   #2
tomm.brz
Drives: brz 2017 hksv2
They ignore you saying about those DTC because there is no reason their tune should give you those codes... and that's actually true usually, neither do I know why you have those code
Their tune is good, your datalogs are probably good, so they probably don't know too what's happening
or they just haven't noticed it while they were focusing on datalogs
email them, Try to insist in helping you
maybe ask if you can try to downgrade to my17 tune that are more proven and defined that the very latest roms
The Following User Says Thank You to tomm.brz For This Useful Post:
BrahmaBull1990 (04-06-2021)
Old 04-06-2021, 09:24 PM   #3
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Okay, thank you very much. I will send them an email tomorrow. My thinking was maybe the o2 sensor from the catless header is upset.
They did acknowledge the idle one and he sent me a new ROM but the code came back a week later.
Can either of these codes damage the engine? As I said, it’s running well.
Old 04-06-2021, 09:47 PM   #4
tomm.brz
Damage is a big word if you are NA
but codes related to the lambda sensor are always not good
if you post here your datalogs with datazap we can take a look too
i dont think lambda is goind bad, that would be extreme unluck... but it can happen. Maybe it is just damaged from installing it to the Tomei
are you super sure you haven't exhaust leak? in both sensors
Maybe Delicious scaled against the leak so the trims are fine but you are running pig rich in low speed
but those things you should ask to them , they tuned you from the beginning
Old 04-06-2021, 10:00 PM   #5
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
I just emailed DT so I’ll see what they say then post a log here. I do not hear any leaks at all; any noise is out the muffler as it should and idles are whisper quiet. I retorqued everything a couple weeks after I installed the header, too, but it can happen.
Thank you, always appreciate your posts
Old 04-07-2021, 12:14 AM   #6
steve99
ecutek retrieves current and old storred codes.
delete all codes see if they come back
if its storred\past code it wont light cel
if its current active code it will
BrahmaBull1990 (04-07-2021)
Old 04-07-2021, 09:12 AM   #7
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Thank you for your input.
I have deleted them before and they come back occasionally, but not with an illuminated CEL; they just show up in the DTC report when I run it, periodically.
Old 04-07-2021, 04:41 PM   #8
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Update:
Received a new ROM already from DT to help out with the P0507 code (which maybe fix the P015A). He said he's seen the P015A code before and sometimes it's the header. So I am sticking with the plan to re-torque the exhaust this weekend.
Already loaded the new tune and all good so far.
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
steve99 (04-08-2021)
EcuTek Help! Pakotron Software Tuning 7 08-20-2020 11:26 AM
Ecutek or oft LOW_and_SLOW Software Tuning 5 12-29-2019 05:24 PM
Ecutek 89_Manny Engine, Exhaust, Bolt-Ons 4 03-09-2018 08:58 AM
used FR-S with Ecutek slowautoxr Software Tuning 13 09-17-2017 05:34 AM
ECUTek TonyWA2015 Northwest 9 10-16-2015 07:00 PM
