Drives: 94 FD, 13 FRS
Advan Center Caps and Advan A052 Qs
Hey, sorry if these question seem stupid but I couldn't really find an answer for these two questions. I'll give some background info first.
Wheels are Advan RZ-F2 18x9.5 +44 Car has Coilovers, VF front fenders (+20mm) 1. Does anyone know if the Advan "Full Flats" will fit over the axle nut? I know the "flats" will fit but I rather have the flush look. 2. Has anyone tried running 265/35/18 Advan A052 yet? I'm asking this because I know these tires are bigger than the RE-71 (No known rubbing problems) and wondering if there are any rubbing issues. I can always run 255/35/18 if needed. If there any info i left out. Let me know and I'll add it if I can get a better answer. I tried to get straight to the point without adding any unecessary info. Thanks for reading and appreciate any help. |
Drives: 2017 BRZ PP, 2004 WRX
I'm on 225/45/17 A052's coming from the same size RE-71R. I was concerned about fitment since they're known to run wide and I'm on the stock suspension.
On the RE-71's, I had 1-2mm of gap between the front strut on +53 17x.75 wheels. With going to the +48 stock ones and adding a 3mm spacer, the A052's have plenty of room. The spacer wasn't really needed and there's at least 5-7mm of clearance, if not more. Long story short, they're probably only 1-2mm wider than the RE-71R's where it counts. Now the Falken RT660's on the other hand... those run wide for sure. You'd want to downgrade a size with those. Not really direct experience with 265's, but moral of the story is I didn't think the Yoks ran as wide as everyone claims. They do look a little balloned for their sidewalls vs the straightness of the RE-71R, but that might the bead area sitting more inward. Tires are weird.
| The Following User Says Thank You to cmiovino For This Useful Post: | Quano (05-23-2021) |
| Advan a052 or other suggestions? | 2Wavy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 07-15-2019 05:51 PM |
| Yokohama Advan A052 review | nikitopo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 12-06-2018 09:18 AM |
| FS:NY White Advan TC2 with caps and tires | GT86drifter | Wheels and Tires | 30 | 08-11-2013 06:44 PM |
| CounterSpace Garage - Advan Center Caps and RAYS Lugs | King Tut | User/Vendor/Sponsor Reviews, Feedback, Comments | 1 | 06-24-2013 07:27 PM |
| Advan Center Caps | Got3n | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 01-19-2013 02:07 PM |
