Old 03-17-2021, 10:56 AM   #1
Biggerhammer
Drives: 2020 BRZ 1999 Miata 2006 F350
DIY Oil cooler
Well after seeing all the oil cooler kits for sale and being blown away by the prices I decided to see if I could hobble something together on my own. Looked on Amazon and found hoses, sandwich plate and oil radiator all for about $250. What am I missing? How are the kits 2-3 times the cost of putting my own together?
Biggerhammer is offline   Reply With Quote
Old 03-17-2021, 11:08 AM   #2
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Perhaps you could post links to the items on Amazon so the forum can see what you are proposing to use?
LimitedSlip is offline   Reply With Quote
Old 03-17-2021, 11:29 AM   #3
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
I second this. There are loads of crappy components out on the market nowadays that need to be sifted through with a fine tooth comb to find one decent part. It's not just e-bay that you have to worry about anymore.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 03-17-2021, 01:10 PM   #4
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I think its a bad idea to just wing it rather than buying a package from a reputable company. Im sure there are exceptions to both however something goes south with any of the components and things wont end well
Old 03-17-2021, 01:11 PM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The money you save piecing it together will leak out of those $6 fittings
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 03-17-2021, 01:46 PM   #6
Ohio Enthusiast
Drives: 2018 BRZ
Do the vendors of kits really use higher quality fittings? Plus what's stopping you from buying these higher quality fittings yourself? The cost saving is there to offset the research and development time, even if all you need to do is verify the correct threads on the oil filter or the right length for the hoses. Plus not counting the time investment into figuring out what to buy and then figuring out how to get everything installed vs. getting a ready made kit with instructions. If people priced their wrenching time they would probably opt for an off the shelf solution, but for most of us wrenching is a hobby and the time spent on it is both free and priceless.
If anything, needing to buy a longer hose after you realize that the routing you thought would work and measured for ends up touching the serpentine belt or something is what will eat up into the cost saving.
But if you do your due diligence well and are prepared to put in the work to figure everything out there's no reason why you shouldn't have a well working oil cooler for much less than a vendor's kit. Just look at the Super/Turbo thread for the exact same discussion on Supercharger and Turbo kits vs. full DIY.
Ohio Enthusiast is online now   Reply With Quote
Old 03-17-2021, 02:22 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Some do, some don't. I think the key is to make sure you are using quality parts when piecing a kit together.
Old 03-17-2021, 05:05 PM   #8
DarkPira7e
DarkPira7e's Avatar
Yeah I think my statement was aimed more at trying to save money with DIY, rather than doing at at near the same cost as a "kit". Having a far better setup as a result of having quality components like Phenix fittings and a Setrab core being the goal. It's not that it can't be done, I've just seen a lot of miserable experiences because of people using cheap fittings and cores. I had a Mishimoto kit myself that didn't leak, but for the same cost I could've made something pretty amazing that suited my setup better
Old 03-17-2021, 06:05 PM   #9
86TOYO2k17
Drives: 2017 toyota 86
Majority of “kits” are pieced together components, create a basic easily recreatable mounting solution, slap on a vendor label, and then charge 30-50% over the price of components. There is nothing unique, special, or proprietary to these kits.
2 oil coolers and 2 trans coolers on 2 cars 0 issues.
Mocal thermostat plate for oil
Derale fluid thermostat for trans
Aeroquip lines
Use Permatex High Temperature Thread Sealant on all fittings
Warm gear clamps for hoses on fittings
I used
Evil energy AN push lock fittings on one cars setup
AC Performance AN push lock fitting on one cars setup
autobahn radiators on one cars setup
evil energy radiators on one cars setup
M5 riv nuts, straight brace, L corner brace, m5 nuts, bolts, washer, and lock washer to mount everything.
If you want to take it a step further
Mount a 4-6 blade fuse box wired to some toggle switches or fluid thermostat solenoid switches wired to some fans. I used 4 - 120mm IP67 160 cfm fans per cooler 2 for intake 2 for exhaust 8 total on car. This has many benefits but can also be a restriction very dependent on where its mounted and car use etc... worked incredibly well for me.
Old 03-19-2021, 08:12 PM   #10
Grady
Grady's Avatar
I do not see any issue building you oil cooler, Just use quality parts. Do not cheep out on hoses and connectors. I pieced mine together, M sandwich plate, M oil cooler. AN quality hoses and fittings. I did not do a extension plate on the adapter I just trimmed the oil filter cup to fit the M sandwich plate.
Old 03-19-2021, 08:20 PM   #11
86TOYO2k17
Originally Posted by Grady View Post
I do not see any issue building you oil cooler, Just use quality parts. Do not cheep out on hoses and connectors. I pieced mine together, M sandwich plate, M oil cooler. AN quality hoses and fittings. I did not do a extension plate on the adapter I just trimmed the oil filter cup to fifth the M sandwich plate.
You can also use the “oem forester cooler” instead of the extension plate and get added bonus of faster warm ups.
Old 03-20-2021, 01:55 AM   #12
DaveB.inVa
Drives: 2016 BRZ Premium
Did this as well using guides here. For the return everything is pretty much factory parts but I deviated for the inlet and have a tee in the radiator hose with the hose traveling across the top of the engine bay attached to a Grimmspeed strut tower bar making the installation a lot easier. Sort of a mix between the Cusco version and factory.
I've got $279 in it, my peak oil temps were brought down from 260-265 to 225-230.
For a street vehicle its great, faster warmup, decently cheap, good fitment using factory parts and just enough cooling to take the edge off.
DaveB.inVa is offline   Reply With Quote
Old 03-20-2021, 07:50 AM   #13
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Maximal Performance puts together all of this stuff for you. It is basically a DIY kit that someone else did all the hard work on. They will even make you custom length hoses if you want to put it somewhere weird. The cheapest kit by a mile. I have had it on my track car for 5 years with no issue.
CLICK HERE
They also sell the mocal thermostat sandwich plate separate if you want to go that route.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 03-20-2021, 02:43 PM   #14
86TOYO2k17
I was saying using them in tandem. You don’t need then spacer plate.’
FS: NJ/NYC OEM (Forester) oil cooler/oil cooler connector Joon525 Engine, Exhaust, Bolt-Ons 3 09-20-2019 05:00 PM
SOLD - RacerX Oil Cooler with Auto Transmission Cooler and Temp Gauge tws98 Engine, Exhaust, Bolt-Ons 0 05-28-2019 10:50 PM
AT Trans Cooler: Performance cooler vs Standard Faulkner Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 04-30-2018 11:34 AM
WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler TheMedakaBox Northern California 4 08-09-2017 10:16 PM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
