Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
03-15-2021, 12:08 PM | #1 |
2013 Engine Warranty recall issues?
I have been putting off the recall work for my car because I am worried about having issues after its done. Has anyone had issues after the recall work was done (from things not being put back together properly)? I need to have some maintenance work done and am wondering if I should have the recall done at the same time. Thanks in advance.
03-15-2021, 12:21 PM | #2 | |
LMGTFY
Drives: 13 FRS, 91 Miata
https://www.ft86club.com/forums/showthread.php?t=133306 |
The Following User Says Thank You to x808drifter For This Useful Post: | Riftur (03-15-2021) |
03-15-2021, 12:35 PM | #3 | |
03-15-2021, 01:04 PM | #4 |
so its basically a crapshoot. You can get lucky and have a tech who knows what they are doing or your engine can be destroyed. If its destroyed, Toyota will say anything so they are not responsible for fixing/replacing it. Thanks for the info.
03-15-2021, 02:04 PM | #5 |
Drives: FR-S,GTI
Just don't do it. It's not worth all the anxiety involved. The chances of valve failure are sooo remote. There's alot less chance of valve failure than your engine being destroyed by the idiots. I think California is the only place that it is required.
The Following User Says Thank You to WNDSRFR For This Useful Post: | Riftur (03-18-2021) |
03-15-2021, 02:27 PM | #6 | |
1st86 Driver!
Odds are good that it will be done properly. There was only a small percentage of failures and most were early on. It needs to be done by a competent mechanic, and preferably by one that has already done several. Ask how many the mechanic has done, and if there have been failures. Also, in most cases, the dealership covered their mistake. In some cases Toyota stepped up to force the repair. The failure isn't actually Toyota's to fix though, its the dealership so your fight is with them. But, as @WNDSRFR said, the odds are likely better you will have a failure of the repair than a failure of the springs. If the springs do fail, Toyota would likely cover the cost of the repair (at least according to the recall). Unless you have to have it done for registration purposes, I'm solidly on the "ignore it" side of the house, even though having mine done over 50,000 miles ago with no issues.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | Riftur (03-18-2021), x808drifter (03-16-2021) |
03-15-2021, 02:30 PM | #7 |
Master Collaborator
Its a ‘13, if one of the springs hasn’t failed yet, it probably won’t. You’re not in California where the recall work is mandated, so just forget about it.
03-18-2021, 12:19 AM | #8 |
My take (having a 2013) is ..... if it ain't broke, why give em a chance to break it .... ??
The Following 3 Users Say Thank You to humfrz For This Useful Post: |
03-26-2021, 03:05 PM | #9 |
Drives: Awesome
i agree- if you have not had issues then i would not chance it.
but personally i would keep a close eye on it just for the sake of it. and if worse comes to worst, then find someone competent and able to do it. ask a dealer or mechanic before hand if they have done it previously. |
04-15-2021, 09:52 AM | #10 | |
04-15-2021, 10:19 AM | #11 | |
Drives: '13 Whiteout
They destroyed my engine |
04-15-2021, 01:19 PM | #12 | |
Drives: 2013 pearl white FR-S
04-15-2021, 01:23 PM | #13 |
Could you tell the engine was not right as soon as you started driving it or did it take time until the engine had issues?
04-15-2021, 02:19 PM | #14 |
It was fine for 3000 miles then went exiting T5 at Laguna. The silicon they got into the block starved the motor for oil. It happened all at once with no warning.
The Following User Says Thank You to TommyW For This Useful Post: | Riftur (04-16-2021) |
Similar Threads | ||||
HELP Worst Mistake Ever - Recall Warranty Work/TOB Replaced at the same time. | Boricua | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 05-05-2022 01:27 AM |
Engine Failure! 2013 Scion Frs. Recall was made | padillaricardo48 | Issues | Warranty | Recalls / TSB | 28 | 08-21-2020 10:41 PM |
2013 Valve Spring recall - modified (FI) engine thread | shiumai | Forced Induction | 71 | 08-11-2020 06:21 PM |
Minor issues after J02 recall... | nextcar | Issues | Warranty | Recalls / TSB | 3 | 11-13-2019 05:31 PM |
Which Portland metro Subaru dealer should I visit for recall/warranty issues? | stockysnail | Northwest | 2 | 01-11-2013 04:42 PM |
