Old 03-14-2021, 09:49 AM   #1
Jstyle
Jstyle's Avatar
Drives: 2020 86
How to get more clearance for my helmet???
So I finally got my helmet (Simpson Diamondback because I’m trying to channel my inner Stig) and I sat in the FRS yesterday. The problem is my helmet is rubbing the headliner pretty solid.
I can lean my seat back a bit and get a solid inch of clearance but I’m sitting back farther than I wanna be. I reach for the steering wheel and my wrists still hit the top so it’s not a HUGE deal, I just want to be up closer.
So my question for the audience, how do I get my seating position any lower? I just need an inch (which is not what she said) and I have it lowered all the way down using the handle the adjustment lever on the left hand side of the seat. Is there any way to go lower other then cutting out the foam or buying a racing seat?
Jstyle is offline   Reply With Quote
Old 03-14-2021, 11:07 AM   #2
Ohio Enthusiast
Drives: 2018 BRZ
Did you flip the headrest front-to-back? From what I heard, it's designed that way to give you better helmet clearance.
Ohio Enthusiast is offline   Reply With Quote
Old 03-14-2021, 11:27 AM   #3
JD001
JD001's Avatar
Drives: Subaru BRZ
I was going to say 'buy a larger fitting racing suit' or whatever you wear when racing.. But I won't as everyone will say that I need to see a therapist!!
Old 03-14-2021, 11:42 AM   #4
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Install Gurney bump.
The Following 4 Users Say Thank You to Sapphireho For This Useful Post:
dsc_pat (03-15-2021), femaledog (03-14-2021), FeRS (03-27-2023), soundman98 (03-14-2021)
Old 03-14-2021, 12:03 PM   #5
ka-t_240
flipping the head rest won't impact the helmet rubbing the headliner.
ka-t_240 is offline   Reply With Quote
The Following User Says Thank You to ka-t_240 For This Useful Post:
timurrrr (03-15-2021)
Old 03-14-2021, 12:36 PM   #6
ls1ac
ls1ac's Avatar
It will move the helmet back a little like moving the seat without moving the shoulders.
The Following User Says Thank You to ls1ac For This Useful Post:
Ohio Enthusiast (03-14-2021)
Old 03-14-2021, 01:15 PM   #7
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
How tall are you? I'm 6'4" and I ended up buying seats. I went with Braum seats and Planted brackets and I gained a good 2 inches. The downside is that this setup doesn't sit as far back as the stock seats so I am definitely closer. That's no big deal for running the car on the track but it's not going to make the car fun on longer trips.
RT-BRZ is offline   Reply With Quote
Old 03-14-2021, 02:05 PM   #8
Ohio Enthusiast
Drives: 2018 BRZ
Exactly. Especially since you said leaning your seat back a little gives you enough headroom. With the headrest in the regular position it will push your head and shoulders forward, similarly to having your seat more upright, taking away head room.
See how much headroom you have without the helmet - if you have more than the shell thickness you should be fine with the headrest flipped. If not that you'd have to either lean the seat back some more or get lower seats (a pain, I know).
Old 03-14-2021, 09:05 PM   #9
Purist
Purist's Avatar
Drives: Subaru BRZ
I'm 6'3". I have my seat right back and reclined so my legs are stretched out so I can heal toe without banging my knees, and my arms fairly straight (I cross my arms on hairpins).
In this position my helmet only just rubs but not enough to notice.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 03-14-2021, 09:08 PM   #10
Jstyle
Jstyle's Avatar
Drives: 2020 86
So I tried to flip the head rest around and it didn’t help at all.
With the seats and brackets does anyone have a measurable amount it saved you headroom wise? My biggest fear is throwing 1500-2000 and it saving me half an inch.
Old 03-15-2021, 09:14 AM   #11
RT-BRZ
RT-BRZ's Avatar
Like I said, I used Planted brackets which get you about as low as you can get.
For seats I got the Braum Elite-X seats. They were only $849 from Evasive Motorsports and the brackets were about $280. The nice thing is that the Braum seats come with sliders so that cost isn't extra. Braum has some very nice reclining seats that weigh close the stock seats or less.
That configuration got me almost 2" lower which allows me raise my seat back more and put me closer to the steering wheel which works better for my track use.
I wouldn't recommend a fixed back seat unless you have a roll bar/cage in the car. That configuration is not safe since they can't collapse properly in case of a rollover.
Old 03-15-2021, 09:30 AM   #12
Jstyle
Jstyle's Avatar
Drives: 2020 86
I'm going to take out the headliner this weekend and see where I'm at. I'm hoping to not have to buy 2k in seats but if I do then it is what it is.
Old 03-15-2021, 08:33 PM   #13
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
One more thing to consider is that if you get an aftermarket seat, it will not have side airbags.
The lack of airbags, combined with this, is what makes me keep the stock seat, at least for now.
A proper roll bar sacrifices the daily'ability of the car, while also adding $$$$ on top of the price of the seat.
I have some ideas on how to make lowering frame for the stock seat,
but my lack of time and mechanical experience are holding me back
timurrrr is offline   Reply With Quote
Old 03-15-2021, 10:16 PM   #14
RT-BRZ
RT-BRZ's Avatar
Understood on the note of the loss of the seat airbags. The remainder work OK but swapping seats means you lose the seat bags.
You could possibly lower the seat itself by removing some padding out of it. The seat frame/rails don't leave much to do however.
What Helmet Do You Use? Pokeguyjai Tracking / Autocross / HPDE / Drifting 69 12-04-2014 08:01 AM
Helmet troubles... Sonolin Tracking / Autocross / HPDE / Drifting 1 10-11-2013 07:10 PM
Helmet Shops Techfl3x Southern California 19 07-17-2013 01:20 AM
Help me helmet Lee358 Tracking / Autocross / HPDE / Drifting 16 06-13-2013 01:53 PM
Need Helmet Advice SVThis Tracking / Autocross / HPDE / Drifting 23 04-13-2013 11:54 AM
