Old 03-08-2021, 02:49 PM   #1
Glock_86
Glock_86's Avatar
Drives: 2013 Scion FR-S Turbo 14PSI
Deleting Purge valve
I have been struggling with this issue for awhile now. just itching my head at it tbh. I have a 2013 scion frs turbo charged. I have a EBCS connected to the CPC port which was the port that the purge valve was connected to. I have plugged the evap Vaccum lines coming off the purge valve. However, my question is i am getting a CEL code. For evap small and large leak and incorrect purge flow. Is this supposed to be a deleted CEL code after the EBCS install after being tuned. or could there possibly be something else that would be causing this.
Glock_86 is offline   Reply With Quote
Old 03-08-2021, 03:21 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Why not plug it in the way it's supposed to be and see if the code goes away? Then you'll have your answer- if it goes away, plug it back into your EBCS and then turn the code off
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 03-08-2021, 03:38 PM   #3
Glock_86
Glock_86's Avatar
Okay i will let you know how that goes tonight. Thanks!
Old 03-08-2021, 04:06 PM   #4
Glock_86
Glock_86's Avatar
Thing is though the evap system runs when the car is being driven. So i will have my purge valve back in but my ebcs disconnecting causing major fluctuations with my turbo. Not really wanting anything bad to happen to the good ole turbiski. soooo i mean i guess i could stay off of it but i would legit have to drive the car.
Old 03-08-2021, 06:11 PM   #5
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Why not just T the purge line and boost control to the same nipple?
Old 03-08-2021, 07:31 PM   #6
DarkPira7e
DarkPira7e's Avatar
Yeah it's a test, definitely not advising that you drive hard like that. Just avoid the gas pedal and see if it silences your CEL
Old 03-09-2021, 08:57 AM   #7
Glock_86
Glock_86's Avatar
I was going to delete the code last night to see if it would come back up, didn't get time, so today I will shoot for it again.
However, I did want to note that I was digging into some forums and found that some people are stating that the EVAP system CEL is deleted for turbo tunes.
I just want someone to have that statement hold true. I tried to email Dynosty (the ones that tuned my car) so i can get reassurance that this is what they have to do with turbo tuning after installing a EBCS on a CPC port. However, i still haven't got a message back from them.
Old 03-09-2021, 09:04 AM   #8
Glock_86
Glock_86's Avatar
AS i wrote this they emailed me back and im scheduling an appointment to see what the issue is. the person im working with stated he has no frame of reference on the matter of deleting the evap system. So im gunna have to bring it in and see what's going on.
Old 03-29-2021, 12:11 PM   #9
Glock_86
Glock_86's Avatar
RESOLVED
ISSUE: CEL CODE for EVAP leaks was not deleted when tuning extensively on Dyno from Dynosty.
Code is now deleted!
Solutions: If you all every run into this issue. where you have a Electronic boost control valve connected to CPC port. Please make sure the EVAP system is deleted/ or codes for the purge valve. or you will get stuck with a check engine light.
cpc, ebcs, evap, leak, purge
Deleting An Account? Luke.Cariveau Site Announcements / Questions / Issues 9 09-20-2022 07:22 AM
Bad ground at purge solenoid connection airrick Electronics | Audio | NAV | Infotainment 1 02-04-2021 09:14 PM
Evap Emissions Purge Flow CEL avishenoy1 Issues | Warranty | Recalls / TSB 5 05-01-2020 06:22 AM
removing purge valve blown Engine, Exhaust, Transmission 0 01-30-2015 03:45 PM
Canister purge solenoid aero.kit Engine, Exhaust, Transmission 1 08-31-2014 02:19 PM
