Old 03-01-2021, 08:16 AM   #1
series420
Drives: '13 Toyobaru BRZ
new summer set
Hello,
Today I am shopping around for summer wheels/tires, I have came up with a combination and was wondering what ya'll thought of it
For wheels i've selected O.Z.
ULTRALEGGERA
Offset:48mm
Backspacing:6.38"
Bolt Pattern:5-100
Rec. Tire Size:235/40-17
Weight:17.2 lbs.
Finish:Matte Matte bronze painted
Construction:1pc. Low Pressure Cast
Finish Warranty:2 Year
https://www.tirerack.com/wheels/Whee...kageFlow=false
and for tires, i have selected
G-FORCE RIVAL S 1.5 - SIZE: 225/45R17
https://www.tirerack.com/tires/tires...cleSearch=true
Let me know what you guys think on the selections, and also the fitment, these are just a bit wider.
Not looking to slide at all, by the way.
Thanks as always guys. may ya'll have a great day.
2013 BRZ Premium
Injen short ram intake, OFT Stage2/e85
Ftspeed UEL headers, JDL front/overpipe, HKS high power dual outlet catback
series420 is offline   Reply With Quote
Old 03-01-2021, 10:18 AM   #2
Vital
Drives: 2015 BRZ
It'll look almost stock like which is good if thats what you want. That tire is great for that size wheel. Yes the wheel and tires a little wider than stock size, but because its a +48 offset which is high it wont stick out a lot. Typically if you want your wheels and tires to be flush with fenders you would need lower offsets.
Vital is offline   Reply With Quote
The Following User Says Thank You to Vital For This Useful Post:
series420 (03-01-2021)
Old 03-01-2021, 03:57 PM   #3
mrg666
pessimistic skeptic
mrg666's Avatar
Konig Dekagram 17x8-40 can be an option for that style. I think 40mm offset is better.
Old 03-01-2021, 04:58 PM   #4
dasting
Drives: 2013 BRZ Limited
Unless you are planning on using those tires to hot lap at autocross/track day and trying to set fast times, you're wasting your money for street use, and you will see diminished life spans. To use those tires to their potential on the street you have to be driving way above the speedlimit in tight roads. If you're on factory alignment settings, you'll just be rolling them onto their shoulders anyway.
2013 BRZ Limited, NASA Instructor, ex-spec miata racer
dasting is offline   Reply With Quote
Old 03-01-2021, 06:22 PM   #5
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Not sure your goal for your car, so can't really say much on your setup. Trying to get more traction? Weekend warrior? Track here and there without breaking the bank? Show car? Just daily? Without a bit more info, we can say anything we want and it'll be legit cuz your question is without context. Why you went w 17" instead of 18" or 19"? Also why 8" width, instead of 9" or 9.5"? Only thing we know is you're not looking to slide. If that's the case, OEM wheels with a bit more stickier tires will be efficient enough.
Old 03-01-2021, 07:00 PM   #6
series420
Intending to use this vehicle for SCCA Autocross and occasional runs down the strip. This will still be my daily driver (20miles or less per day) but will see its fair share of the track... once or so weekly
I have since posted this updated the size to 18s and switched out the tires to RE-71s as they can handle wet conditions better.
Why 8", Im not too sure much larger will be beneficial for me, however im no professional so I very well could be wrong on that.. also not lookin to have my tires stick out an inch past my fenders.
Thanks for the reply, hope this helps.
2013 BRZ Premium
Old 03-01-2021, 07:38 PM   #7
ichitaka05
Site Moderator
ichitaka05's Avatar
That actually help a lot more.
So going with your info, if you want, you have a bit more options.
If you wanna stay in 17's. Can do 8~9 width (depends on which autox class you wanna stay). Offset, you got technically go til +32, it won't poke out (depends on wheel design, tire width & camber).
You can go into 18's. Just remember wider and bigger you go, less comfortable daily driving gonna be (due to tire wall).
As for the tire setup, 225 width is a standard for the twins... unless you put FI, then it's different story.Bolt on mods won't need wider than 225 tires, just get stickier tires. From there, you decide on how sticky you want your tires. But like other member said, more sticky it gets life of the tires become shorter.
I had good amount of different wheels & tires setup. Wheels: 17x8+55, 17x9+35, & 18x8+35. Tires: 235/40-17, 245/40-17 & 225/40-18. But in the end, I enjoy 17x8+35 w 225/45-17 setup for everything. Great offset, flushed w the fenders (maybe just fraction inside) & tires get enough traction.
The Following 3 Users Say Thank You to ichitaka05 For This Useful Post:
ls1ac (03-03-2021), series420 (03-01-2021), warhawk03 (03-01-2021)
Old 03-01-2021, 07:42 PM   #8
warhawk03
Drives: 2018 BRZ
I picked up a set of Ultraleggera's 17x8 +48 (Satin Black) last fall. I mounted 235/40/17 Falken RT660's, and I've been happy with them.
I autocross the car and had a couple events before the season ended last year. I was pleased with the upgrade (coming from stock wheels and 215/45/17 RE-71's), but I need more seat time to really give a good opinion.
The +48 option is a nice OEM+ fit. You can get +35 from Tire Rack, but you have to search for a 4th generation Jetta (1999-2004) to see it available. The bolt pattern is 5x100, but I think the hub-centric rings might not be right.
I'd buy these wheels again (I actually might for a different color). I think 17's are better for autocross, but I'm not an expert by any means. There's a bunch of good options for tires in the 200TW rating (RE-71's, A052's, RT660's, and more) so it's a bit of a personal choice and whatever the budget allows. If you want RE-71's, get them while you can.
Check out the wheel directory threads for both the +48 or +35 to get more info.
warhawk03 is offline   Reply With Quote
The Following User Says Thank You to warhawk03 For This Useful Post:
Old 03-01-2021, 09:37 PM   #9
series420
Thank you very much, great info. I think ill go with the 18's with 225s.
2013 BRZ Premium
Old 03-01-2021, 09:38 PM   #10
series420
great to hear from someone who owns these wheels, I have pulled the trigger and ordered mine, I went with the gold in subaru fashion
2013 BRZ Premium
Old 03-02-2021, 12:51 PM   #11
series420
Thanks everyone for your input, I feel confident Ive made the right selection with ya'lls help!
Side note, I placed my order at tire rack 14 hours ago, and the wheels and tires are already here. Free shipping that is fast ftw
2013 BRZ Premium
Old 03-02-2021, 10:32 PM   #12
Israel Moore
Drives: 2015 Subaru BRZ Limited
I agree Konig will probably be one of the best options to consider.
Israel Moore is offline   Reply With Quote
Old 03-05-2021, 02:32 AM   #13
wil5bart
Drives: '16 BRZ
Cool. Post some pics once you're done installing them.
wil5bart is offline   Reply With Quote
Old 03-05-2021, 12:26 PM   #14
series420
Here is one I took the day of install. Front rim is missing its center cap, I broke it, I've replaced it already though.
Strangly I can never see the pics I post, not sure if Im doing something wrong, or if they show up for you guys..
https://ibb.co/zh4Rmbz <link to image if it doesnt load properly
2013 BRZ Premium
Summer or All season? Flame9020 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 02-04-2017 10:00 PM
Another PDX summer bbq Jonesy86 Northwest 112 07-27-2015 10:41 AM
end of summer mafrs1 Canada Classifieds 2 09-07-2014 11:32 PM
Summer driving Suberman CANADA 24 01-13-2014 03:27 PM
Best $100 Summer Tire in 225/45/17 Black Tire Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 03-07-2013 07:22 PM
