Old 02-22-2021, 03:13 AM   #1
TorontoB
Drives: Brz
Sprintex supercharger
Sprintex 22 psi has anyone tried this? How would it work with a 200 shot of nitrous?
TorontoB is offline   Reply With Quote
Old 02-22-2021, 10:54 AM   #2
86TOYO2k17
Drives: 2017 toyota 86
I'm assuming you are talking about the sprintex 335?
Stacked with a 200 shot would work great once for about 5 seconds, then time for an engine rebuild.
The 335 unless you get the largest pulley and detune it, already needs a built block. Pushing the 335 at 22 psi with all bolt on / supporting mods / E85 should get you to 400whp with 300+ ft lbs. This alone is plenty for the chassis / weight and would be pushing the built block by itself, a 200 shot on top would probably wreck the built block in a few pulls.
Nitrous stacked on FI seems pointless on this platform.
A 50 shot stacked on top of a full NA bolt on E85 build could work pretty good if setup properly, should pull as hard as a lot of mild FI setups.
Old 02-23-2021, 08:43 PM   #3
TorontoB
Drives: Brz
Thanks for info!
Sprintex 210 Supercharger xezzecm Engine, Exhaust, Bolt-Ons 6 12-13-2019 10:16 AM
Sprintex Supercharger Jakebowles Engine, Exhaust, Bolt-Ons 1 08-11-2016 02:24 PM
Innovate/Sprintex Supercharger erbaker67 Engine, Exhaust, Bolt-Ons 6 05-27-2015 07:54 PM
Sprintex Supercharger Group BUY! Xero-Limit Groupbuys 44 02-14-2015 03:13 PM
The new sprintex 335 supercharger jet86 Forced Induction 39 11-01-2014 11:27 AM
