Drives: Brz 2016
Need help, White dust in the exhaust
I came back from work today. When I got home I realized there is white dust inside my exhaust tips. The car felt fine. Checked for codes and nothing showed up. Any ideas or tips would be appreciated!
#2 | |
Sent from my IN2017 using Tapatalk |
Drives: Brz 2016
Master Collaborator
I was going to ask you what that white dust tastes like thinking it's road salt, but I see that you're in Mexico.
I'll guess maybe coolant residue from a possible blown head gasket? |
Drives: Brz 2016
OHH noo. I thought about it. Did the basic checks, no brown oil, no coolant discolor, no white smoke, no overheating. I guess ill take it to the mechanic shop this week for further inspection.
Drives: 2015 FR-S
Check for catalytic converter failure.
Drives: Awesome
going to second about the catalytic - might want to check that out.
Drives: 2015 BRZ WRB
Sorry op, I can't help it....
AutoX-10/10ths every run
I had the cat in my stock header fail at one point and it covered the entire rear bumper of the car with dust that looked just like that.
#10 | |
OP it’s probably your cat as mentioned above. |
#11 |
Could be running lean. Has the car been modified or tuned?
#12 |
Hello,
I was curious if you ever figured out what was causing the white dust. I had exactly the same thing happen to my car this past weekend. Also nothing weird with the oil or coolant. I’m suspecting a damaged cat. Eager to hear what you learned. Thanks, Mark |
#13 | |
Drives: SWP BRZ
#14 | |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Code:
Palmermc Junior Member Join Date: Aug 2021 Drives: 2013 BRZ Location: CA Posts: 1 Thanks: 0 Thanked 0 Times in 0 Posts Mentioned: 0 Post(s) Tagged: 0 Thread(s) Trader Rating: 0 reviews |
| WTB: Shifter Linkage Dust Boot & Shifter Dust Boot | Erick.Hnandez | Want-To-Buy Requests | 6 | 01-27-2021 05:58 PM |
| white powder thing in my exhaust tip | 2JZ-GTE | Engine, Exhaust, Transmission | 14 | 01-08-2015 12:51 AM |
| Brake dust or rail dust? Dealership bs? | Muskokan | Issues | Warranty | Recalls / TSB | 12 | 12-21-2013 09:30 AM |
| white Frs bites the dust | Fallen43 | CANADA | 8 | 10-06-2013 08:49 AM |
| White M/T FRS with exhaust $23k | yayforaddison | Cars for Sale/Trade | 1 | 03-29-2013 09:59 AM |
