Old 02-18-2021, 05:40 PM   #1
Currentwar
Drives: Scion FRS
Unhappy HELP!!!! Second gear won’t engage
I just finish installing new exedy oem clucth and flywheel. Also install mtec shifter spring. Atfer installing i tried to shift every gear and i can’t shift on 2nd gear. But everything else is fine 1,3,4,5,6,R are doing fine. Shifting like a butter. Except 2nd. I also try to put on 1st without gas pedal, it engage smoothly wheels are running. I feel so frustrated im working by my self so. Need some help
Currentwar is offline   Reply With Quote
Old 02-18-2021, 06:16 PM   #2
Ashikabi
Ashikabi's Avatar
Have you tried adjusting your clutch pedal a little?
Old 02-18-2021, 06:57 PM   #3
Currentwar
Drives: Scion FRS
No i don’t adjust just doing clucth. Im going try if that work.
Old 02-18-2021, 07:00 PM   #4
Ashikabi
Ashikabi's Avatar
Let us know how it goes
Old 02-19-2021, 05:52 AM   #5
Currentwar
Drives: Scion FRS
Update..
i inspect clucth pedal and i got leak on clucth line on the slave cylinder so hope fully this work also how to check if my slave cylinder has leak i saw clucth line wet but maybe it was from the line. And since im going to adjust clucth pedal im buying mtec clucth spring.
Old 02-20-2021, 09:54 PM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
Did you remove the gearshift lever? If so, did you properly align the the top plate when reinstalling it? See service manual link in my sig line.
If you don't have it aligned properly, it'll keep you from getting into either, or both first and second gear.
Old 10-29-2021, 05:05 AM   #7
Currentwar
Drives: Scion FRS
Thank you for all your help it finally... i can drive it smooth.
Stiff to engage 1st/reverse from a stop after clutch install mhiscott Engine, Exhaust, Transmission 94 07-19-2020 07:11 PM
Clutch Engage Whine? PDM 2 Issues | Warranty | Recalls / TSB 12 10-25-2016 03:11 AM
Transmission won't engage any gears.. Diff/Axle is done. Rifle Issues | Warranty | Recalls / TSB 35 03-29-2016 12:36 PM
Automatic transmission hard parking engage and disengage nos145 Issues | Warranty | Recalls / TSB 21 09-18-2015 07:30 PM
clutch won't fully engage/8000 miles small dent stockscionfrs Scion FR-S / Toyota 86 GT86 General Forum 2 10-14-2014 11:06 AM
