Old 02-11-2021, 01:14 PM   #1
czellers
czellers's Avatar
Drives: 2K19 GT86
MAF/Fuel Trims Question
Question regarding LTFTs. Per the statements below from the following post [ https://www.ft86club.com/forums/showthread.php?t=64790 ] :
"The correction applied by the ECU due to the O2 sensor input will be in the form of STFT, if the STFT stays negative or positive consistently for a period of time it will be written to LTFT. There are several bands of LTFT based on MAF sensor flow rates (roughly related to engine RPM) where the ECU stores the LTFT."
So my question is, regarding LTFTs specifically, does disconnecting the battery wipe the stored LTFT data, or is it only "stored" for that drive cycle or until the "stored" data sees a specific delta/change, and is subsequently overwritten?
czellers is offline   Reply With Quote
Old 02-11-2021, 01:34 PM   #2
tomm.brz
Drives: brz 2017 hksv2
disconnecting battery resets like an ecu reflash, LTFT will stay at 0 for a while , and after a bit of driving in closed loop the ecu will start learning LTFT and when it starts it never stops learning and updating the values
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
BrahmaBull1990 (02-26-2021), czellers (02-11-2021)
high fuel trims dholloway543 Software Tuning 3 12-21-2020 03:57 AM
Understanding Fuel Trims ShadowReaper Software Tuning 13 04-01-2018 12:34 PM
Negative Fuel Trims No CEL Neiman Issues | Warranty | Recalls / TSB 1 06-01-2017 07:58 PM
Fuel trims are f***** up tskaohu Software Tuning 11 02-23-2016 09:53 PM
Fuel trims video mike_ekim1024 Software Tuning 1 12-20-2013 08:01 AM
