Old 01-30-2021, 04:47 PM   #1
elitegunslinger
elitegunslinger's Avatar
Drives: 2014 BRZ Limited
FS: New parts to build an FA20
Everything is sold... delete
I've had some obligations come up that I need to settle; looking for someone to pickup everything for $3150 obo; located NJ 08050.
Here's a link to the photo album: Click Here
Open to offers if you would like pieces.
JE Pistons & Rings 10.5:1 STD 86mm (file fit and ready top .020, bottom .023) 315117 $500
Engine Seal Kit 10105AB550 $160
ARP Main Bolt 203-5002 $350
ARP Head Studs 260-4301 $200
Skunk2 Alpha Rods 306-12-1010 $350
New Crankshaft (balanced to 8200 rpm) 12200AA490 $500
XPG King Race Main Bearings STD MB5745XPG $120
XPG King Race Rod Bearings STD CR4616XPG $90
GSC Valve Springs 5756 $250
GSC Valve Seals 1023 $20
2x 5oz Tubes of ThreeBond 1217H $45 for both
VIN on block JF1ZNAA16D1729776 40k miles approx. 2013 FRS
[ Entire long block assembly disassembled, not all parts listed ]
Block halves (honed and ready to be put together) $400
Oil Pan
Timing Cover
Factory Injectors
Factory Intake Manifold / Fuel Rails
Timing Chain / Tensioner / Guides
Both complete heads with cams $500
Factory crankshaft (damaged due to low oil, trash)
Factory Pistons/Rods (good shape)
Factory Coil Packs (2 out of 4 available still)
Hardware
Pending:
Sold:
denstoj Rocker Stoppers $650
Killer B Oil Pickup $110
Bluemoon Oil Baffle BMZN6-EOBP1 $100
elitegunslinger is offline   Reply With Quote
The Following User Says Thank You to elitegunslinger For This Useful Post:
MICHAEL450f (01-30-2021)
Old 01-30-2021, 09:19 PM   #2
Silviacrazed
Drives: 2016 Scion FR-S
I’d be interested in the oil baffle and pickup tube if you separate.
Silviacrazed is offline   Reply With Quote
The Following User Says Thank You to Silviacrazed For This Useful Post:
elitegunslinger (01-30-2021)
Old 01-30-2021, 10:18 PM   #3
Jdmjunkie
Drives: Scion FR-S 10 Series
I will take the rocker stoppers, if you sell them.
Jdmjunkie is offline   Reply With Quote
The Following User Says Thank You to Jdmjunkie For This Useful Post:
elitegunslinger (01-31-2021)
Old 02-04-2021, 06:49 PM   #4
elitegunslinger
Willing to meet up with someone if they're interested in the lot.
Old 04-10-2021, 08:21 PM   #5
jrhudson
Drives: 2016 scion frs
Pm sent
jrhudson is offline   Reply With Quote
Old 07-02-2021, 09:12 AM   #6
trave9161991
Drives: 2013 Scion FRS Asphalt
Are any of these still available? Sent a PM
trave9161991 is offline   Reply With Quote
Old 11-23-2021, 12:23 PM   #7
elitegunslinger
Sold!
FA20 short block build usp2333 Engine Swaps 25 09-22-2019 09:02 PM
2014 Limited Subaru BRZ - parts from my build - All parts have 6,000 miles... 2013GTRNate Engine, Exhaust, Bolt-Ons 2 03-28-2018 06:18 PM
FA20 Parts - lots of parts and pics seant2h Engine, Exhaust, Bolt-Ons 5 08-16-2017 03:38 PM
Should I build an FA20? Nah Engine, Exhaust, Transmission 27 03-31-2017 10:22 AM
FA20 January motor build special -Phil Engine, Exhaust, Bolt-Ons 10 01-20-2016 10:34 AM
