Old 01-28-2021, 08:15 PM   #1
Sphinx
Drives: 18 BRZ PP & 99 Spec Miata
Wheels for SSC?
I was reading an old SCCA article and it mentioned that TireRack was selling one of their TR Motorsports rims for the SSC class, but I see no trace of it on the TR site.
In the absence of that, what's a decent and cheap wheel that you guys like for SSC?
Looks like the car fits in DS too. But why is the 86 without TRD suspension = BRZ with Performance Package?
I've always thought that the PP and the TRD parts were all the same stuff.
Sphinx is offline   Reply With Quote
Old 01-29-2021, 03:59 AM   #2
strat61caster
strat61caster's Avatar
TR Motorsport C4 shows up just fine when I look. Make sure you put in solo spec coupe when selecting a vehicle to shop for.
https://www.tirerack.com/wheels/Whee...4&autoModClar=
TRD suspension includes lowering springs which are stiffer and thus notably better performing then OEM FRS/86/BRZ. The BRZ performance package does not come with any meaningful suspension changes instead focusing on 0.5" wider wheels, PS4S tires, and pretty brake calipers.
https://www.caranddriver.com/reviews...-drive-review/
Note that the performance package only comes on '17+ BRZ's which are not eligible for SSC which only allows the '13-'16 FRS/BRZ.
ineedyourdiddly
Old 01-29-2021, 09:32 AM   #3
Sphinx
I see them now - from a fitment perspective, I would have thought that they would at least show up when searching for an 18, even if the car isn't eligible for the class. Thanks. At least I can put some track tires on those rims. I presume that they'll clear the PP brakes?
Got it on the suspension side - I thought it came with better springs, but alas. Are the TRD shocks tuned differently than the PP ones? I figure OEMs are usually lazy, especially if it comes to relatively low volume sales.
Old 01-29-2021, 11:55 AM   #4
ka-t_240
17+ cars are not able to be used for SSC. The 17+ PP comes with different struts as well. They are not the same struts from the TRD Packaged FRS.
If you have a 17+, stick to street class or bump up to STX.
ka-t_240 is offline   Reply With Quote
Old 01-29-2021, 12:56 PM   #5
Sphinx
Good advice, thanks. *checks autocross schedule* Like will stick with stock, maybe even with the prius tires.
For track day sticky rubber, would the rims fit the PP brakes?
Old 01-29-2021, 03:07 PM   #6
ka-t_240
In the street class, you can put some sticky 200tw tires, even change your wheels(stock width only, can go to a 17 or 18, near stock offset).
I would run your stock wheels and tires for autox and track, when the tires are toast, upgrade them at that point.
With the PP, you will need to find the thread that has wheels that fit with the calipers in the wheel section on here.
Old 01-30-2021, 02:10 AM   #7
strat61caster
Tire rack actually may not be confident that they clear the pp brakes, you can contact them directly and they usually know why.
Trd spec doesn't come with any changes to the dampers iirc, which doesn't matter because you'll want koni yellows or mcs for Street class anyway. Same story for PP. The special brz ts has bilsteins otherwise you just get year over year tweaks.
ineedyourdiddly
*Wheels Collection* Winter Package 2015-2016 (Alloy Wheels + Tires) wheelsco Canada Classifieds 4 10-08-2015 03:55 PM
TWS Forged Wheels T66-F - Ultra lightweight Race Wheels with Style // DSG Performance Jason@DSG Wheels and Tires 37 12-17-2014 02:50 PM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 02:21 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 10:08 PM
