Northern California NorCal
Old 01-27-2021, 10:28 PM   #1
H4WKE
H4WKE's Avatar
Drives: Soon to Own BRZ
Bay Area Subaru Dealer for Valve Spring Recall?
I know I'm late on the recall but I was wondering if you all could help me decide which Subaru dealer to take my BRZ to for the valve spring recall? Or which ones to avoid? Thanks in advance for the help!
H4WKE is offline   Reply With Quote
Old 01-27-2021, 11:36 PM   #2
steezypenguin
steezypenguin's Avatar
Drives: SWP BRZ
Fremont Subaru will be your best bet. it's been 10k miles since I've had the recall done and no problems *knock on wood*. Currently at ~113k miles
steezypenguin is offline   Reply With Quote
Old 02-01-2021, 03:29 PM   #3
H4WKE
H4WKE's Avatar
I'll give them a call. Thanks for the recommendation!
Old 02-08-2021, 01:18 PM   #4
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Second for Fremont. 12k miles here, no problems. I checked the car when picking it up and found they did snap my engine cover so I asked them for a new one before leaving.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 03-17-2021, 01:02 AM   #5
eherschend
Carlsen subaru was the only dealership that would touch my car because it was supercharged. Still haven't blown up
eherschend is offline   Reply With Quote
Old 05-11-2021, 09:48 PM   #6
ruzzmon
Drives: BRZ DGM
Did anyone else also have a clutch put in during the valve spring recall? Dealer is suggesting clutch, pressure plate, flywheel, fork (?), and TOB for $1400 which sounds extremely high. Labor is 30min which sound fine.
ruzzmon is offline   Reply With Quote
valve spring recall - dealer experience DarkSideFRS Southern California 173 10-12-2020 07:26 PM
J02 Valve Spring Recall @ Subaru Pacific? dlux Southern California 5 12-11-2019 12:49 PM
Valve float after valve spring recall mswbrz Issues | Warranty | Recalls / TSB 5 11-22-2019 07:03 PM
Dealer recommendation for valve spring recall: South of Seattle rice_classic Northwest 8 03-17-2019 03:06 AM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 03:35 PM
