Drives: TRD R.S. 1.0 FRS
Condensation under hood?
I noticed a few mornings ago that there was condensation on the underside of the hood. It has been cold but no rain. At first i didnt really think anything of it but today it has condensation on there again. Some water was on my intercooler and pipes.
Is the condensation normal? Im most likely gonna just ignore this since theres no problems with it other than some of the engine bay is a little wet |
Well, my 2013 FR-S doesn't do that.
Have you checked for any cooling system leaks? Do you park outside or is it garaged? |
Rust bucket enthusiast
Maybe check your intercooler piping ( inside) to see if it is wet. If the blow-off valve is pointed upwards, it could be releasing vapor (indicating that something is wrong, you shouldn't have that much vapor in your piping!)
It's probably nothing, but probably is why you're asking, so I'd keep wondering until you can rule out anything serious
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
#4 | ||
whats the best way to check for cooling system leaks? i usually just park it on a flat surface overnight and check the next day but its raining alot so yea gotta wait for that to stop. Quote:
Ill update later when it stops raining to see if its gone. Last edited by airrick; 01-28-2021 at 07:26 AM. Reason: info |
#5 | |
As far as detecting a cooling system leak, the only way I know is to "look and see".
| SOLD: Seibon VS-Style Carbon Fiber Hood w/ Quik Latch Hood Pins | sixthspeed | Exterior Parts (Aero, Lighting, Etc.) | 16 | 02-07-2021 08:49 PM |
| FS: Seibon Carbon TS hood, Sparco hood pins, Clear coated $650 (Lawndale) | iceblaze | Southern California | 1 | 04-14-2019 03:50 PM |
| BRZ DRL Condensation | Perihelion | Issues | Warranty | Recalls / TSB | 8 | 03-02-2016 12:23 PM |
| DRL has condensation. | ARTBRZ | Issues | Warranty | Recalls / TSB | 13 | 01-22-2015 08:30 PM |
