Old 01-16-2021, 10:43 PM   #1
dholloway543
Software Hobbiest
Drives: 2015 FRS
Wideband O2 Tuning
I have installed a wideband o2 sensor on the downpipe to the sbd500x turbo kit. Everything seems fine except for at 2800rpm to 3000rpm i get a weird resonance that i cant seem to figure out where its coming from.
https://datazap.me/u/dholloway543/we...zoom=1160-2425
The O2 #2 Voltage is my wideband. You can calculate the AFR on the sensor with this equation.
AFR = 3.008 * Voltage + 7.35
I used excel to add the Fuel trim combined line and trimmed out the section that is bad.
Any ideas on what might cause it would help out alot
dholloway543 is offline   Reply With Quote
Old 01-17-2021, 12:29 AM   #2
dholloway543
Software Hobbiest
Drives: 2015 FRS
After looking closer at it, it looks like the throttle pedal is reading the values like that. Is there a smoothing value in ecutek
Old 01-17-2021, 02:57 AM   #3
tomm.brz
Drives: brz 2017 hksv2
how did you connected it and where did you take the power for it and what did you do on the racerom tables to try make it working?
i have a wideband 24/7 in my headers and i get toatlly different signal in the o2 connector, it seems it isnt working
racerom has everything to make the wideband afr viewable without conversions directly in log trhough the value "Wideband AFR"
that was an old test while i was tuning everything , but you can see o2 voltage and Wideband afr
https://datazap.me/u/tommbrz/io-v400...1&zoom=142-351
Old 01-17-2021, 03:08 AM   #4
steve99
Maybe turn off the ecutek closed loop fueling till you get wideband sorted as its causing wild swings in afr due to the weird readings from the wideband i suspect.
also injector pulse widths dont seem to be logging which is strange. you can use pulsewidths to check if the afr reading is correct ie if you see more pulsewidths and afr going leaner its likely not correct.
Also rescale the front 02 sensor you wont rearly needcthe wideband and the wideband should read failry similar to the front 02.
Old 01-17-2021, 03:23 PM   #5
dholloway543
Software Hobbiest
Drives: 2015 FRS
So you were right, The LC-2 defaults to a specific voltage before its calibrated. I found the link here
https://redirect.viglink.com/?format...C-2_Manual.pdf
and now that its calibrated it spits out correct voltages
The Following User Says Thank You to dholloway543 For This Useful Post:
steve99 (01-17-2021)
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 03:15 AM
Question about wideband and software tuning post_break Software Tuning 5 04-08-2014 09:53 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 06:33 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
