Old 01-01-2021, 08:25 PM   #1
Smaay
Drives: 2013 FRS
Backup camera on 2013 with Kenwood HU
Hello all, I been racking my brain on installing this camera. I am good on the reverse signal (pink wire in kick panel) that gets added to pin 2 on the 28 pin connector. What im confused on is the 6v power source for the camera.
this is the kit I got
https://camerasource.com/automotive-...amera-kit.html
I have a Kenwood DNX6904 with a Maestro RR already installed. I cant seem to find the blue/yellow wire from the maestro that supplies the 6v signal to the camera.
Is it on a sub harness that is not plugged onto the RR?
I assume that will go to the red wire on the camera, and of course the black will be a ground.
this thread helped a little
https://www.ft86club.com/forums/show...5&postcount=20
Other forums seem to agree that there should be a 6V blue/yellow wire on the RR, I cant find it
Thanks for the help
JC
Smaay is offline   Reply With Quote
Old 01-01-2021, 08:51 PM   #2
Smaay
Drives: 2013 FRS
Looking a little deeper, it appears that the TOY1 harness kit comes with what i need.
I have the same setup in m wifes Forester and I dont remember going through this, then again, it already had a camera
2013 add backup camera + head unit lynnmichelle DIY (Do-It-Yourself) Guides 7 10-09-2019 09:21 AM
Backup Camera input/recommendations for 2014 Monogram without factory Backup Camera RedLeaderD4S Electronics | Audio | NAV | Infotainment 3 08-04-2017 08:32 PM
2013 Subaru BRZ backup camera install Foofg DIY (Do-It-Yourself) Guides 9 01-09-2016 04:01 PM
SOLD - Rydeen Duo ZH07-150B Backup Camera and Rear Camera SVXdc Harness NanDAssi Audio/Visual, Electronics, Infotainment, NAV 5 11-24-2015 05:06 PM
Kenwood CMOS-210 Backup Camera Install TSY Electronics | Audio | NAV | Infotainment 34 12-10-2014 01:18 PM
