Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-22-2020, 02:43 PM   #1
AnalogMan
AnalogMan's Avatar
Drives: 2019 BRZ Limited 6 speed Red
Targa top
This is the Supra, but if this was done for the BRZ/86, I'd be the first one in line to buy one (regardless of whether it was the first or second gen car):
https://jalopnik.com/the-2021-gr-sup...-ne-1845929374
The world needs more removable roofs...
AnalogMan is offline   Reply With Quote
Old 12-22-2020, 02:49 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I had one of very few targa top kits ever made on my 3000GT VR4.
Believe me, it sucks to try and get the car structurally sound after having it done.
Stopping it from leaking, creaking, blegh.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 12-22-2020, 02:55 PM   #3
joro2
joro2's Avatar
Drives: 2017 BRZ Premium MT (DGM)
Would have liked simple manually* removable panels where each roof bubble is, which seemed structurally do-able as that section (either side of the center brace) on the unibody is I believe blank (and covered with a separate piece - e.g. like the carbon fiber option on the S209 STI models) .
*As if anyone does that in the 21st century, but a simple solution I miss from the old days. And of course w/o the creaks & leaks.
joro2 is offline   Reply With Quote
Old 12-22-2020, 03:08 PM   #4
Tokay444
Anti stance.
Tokay444's Avatar
Having been in roll-over, I'll keep the roof where it belongs forever and always, unless there's a full cage option.
Old 12-22-2020, 05:59 PM   #5
AnalogMan
AnalogMan's Avatar
Yeah, it basically turns the car into a convertible, and needs all the usual structural reinforcements - which add weight and cost, and still don’t give the torsional rigidity of a fixed roof.
But it sure would be fun.
Old 12-22-2020, 06:08 PM   #6
AnalogMan
AnalogMan's Avatar
Do you mean T-tops? T-tops (keeping a center bar) were all the rage in the 70’s and 80’s. I had a 1992 Nissan NX2000 with T-tops, and absolutely loved it!
It was a reasonable compromise design. It wasn’t as stiff as a fixed roof, there could still be some axial twisting, but it was better than cutting the entire roof out and seemed to nicely address longitudinal flexing.
Some people didn’t take them out that often, finding it a nuisance to have to remove two separate panels. I didn’t mind. Just a couple of minutes and it was a near-convertible experience, with the safety and security of a rigid top.
It’s been so long since any car has been offered with T-tops, probably 25 years. I suspect all the designers have long since forgotten about them, or written them off as obsolete. It would be a cool, gutsy move for someone to bring them back (cough cough, are you listening Subaru?), but the odds are probably even less than ever seeing a factory turbo.
Old 12-22-2020, 06:35 PM   #7
Willpower
The Power of Will
Willpower's Avatar
Drives: 17 BRZ PP, 02 S2000, 21 Mojave
T-top was made up until at least the 2002 Camaro. They were great back in the day, and it was hard to beat an IROC Camaro with a t-top in the 80s. I know there’s a mullet stigma haha, but damn they were and still are great looking cars. Although structural rigidity took a hit with the removable roof panels.
The current Jeep Wranglers have their Freedom panels, which remind me very much of the old t-top, but there is no center bar, just interlocking twin panels. Love it on my Rubicon. Nostalgic.
Willpower is offline   Reply With Quote
Old 12-22-2020, 10:57 PM   #8
dpfarr
Drives: BRZ ts
What I would give for a late 80s 911 targa.
dpfarr is offline   Reply With Quote
Old 12-22-2020, 11:51 PM   #9
Red-86
Drives: 86 (sold), 370Z
Yeah, I'm good with a proper hardtop roof. If you must, put a sunroof in. Or get a convertible. I'd actually prefer an MX-5 RF style fully retractable roof to a targa, it's got many of the same issues with potential leaks, creaks and rattles, but at least it is quick and easy to raise and lower the roof electronically. Manually fiddling around with a targa top is so 1990s.
Red-86 is offline   Reply With Quote
Old 12-23-2020, 12:22 AM   #10
Red-86
I think the mechanical folding roof has largely replaced them.
Old 12-23-2020, 06:13 AM   #11
Willpower
The Power of Will
Willpower's Avatar
The RF is a targa. It’s just a targa with mechanical actuation.
Old 12-23-2020, 08:37 AM   #12
ZDan
ZDan's Avatar
Drives: '23 BRZ
For me, "targa" implies a *fixed* hoop behind the driver/passenger, as on Porsche 911 Targa and Corvettes since 1984 (or 1968 if T-tops are considered a variation of "targa").
I had a '90 RX-7 convertible where you cold remove the roof panel by itself which gave a targa look, but I wouldn't call that or the Miata RF a targa.
But anyway, IMO targas and T-tops are a bad idea, at least for cars that aspire to be relatively lightweight and sporting... A fixed roof is an extremely mass-efficient way to get stiffness. Having a removable panel means you have to make up for the stiffness lost by beefing up the lower chassis of the car, which is much less efficient and adds mass.
Mazda should make a fixed-roof version of the Miata, which if properly done could *reduce* weight by 100 lb. instead of the RF, which *adds* 100 lb. Although they'd likely just take the increase in stiffness without subtracting structural mass anywhere, which should be roughly weight-neutral...
Old 12-23-2020, 09:23 AM   #13
AnalogMan
AnalogMan's Avatar
A mechanical folding roof like the Miata gives a full convertible experience, but is also much more complex, heavier, and expensive than T-tops. I can't imagine Subaru/Toyota doing that with this car.
I was trying to think of a way Subaru/Toyota could add some kind of quasi-open air experience to the BRZ/86 without needing major surgery (or expense) on the car. A targa top would be fun, but would need extensive structural reinforcements that might not be practical. T-tops would seem to need less.
At a minimum, how about a large removable sunroof, such as used to be available on the Porsche 924? I think that by leaving the perimeter roof channels intact, most of the structural integrity of the body is maintained. I don't think the sheetmetal in the middle contributes much. The entire panel could be lifted out and stored in the back (maybe even with some clips to attach it in the storage area). Something like this:
Old 12-23-2020, 10:06 AM   #14
Willpower
The Power of Will
Willpower's Avatar
I believe targas are referring to the entire overhead panel being open, and I think the RF is referred to in articles and literature as a targa, but I could be mistaken. Bad idea for structural rigidity for sure, but cool as heck for just cruising. Not as immersive an experience as a true convertible, but targas and t-top cars allow one to preserve the exterior aesthetics of a coupe while still being able to have a nice open air experience. IMO targas and t-top cars feel much more open air than sun roofs.
Targa Top FRS Conversion? Alott53 Scion FR-S / Toyota 86 GT86 General Forum 33 08-03-2015 09:48 AM
FR-S takes 3rd at Targa Newfoundland DarkSunrise Scion FR-S / Toyota 86 GT86 General Forum 1 06-11-2015 11:02 AM
Targa Newfoundland Sept 2012 diirk Tracking / Autocross / HPDE / Drifting 10 11-24-2014 01:05 AM
Targa top!! fingjosh Scion FR-S / Toyota 86 GT86 General Forum 52 11-03-2014 12:08 PM
FS/FT for BRZ/FRS 911 Targa Sterling Doc Cars for Sale/Trade 22 09-23-2013 11:18 PM
