Old 12-20-2020, 11:53 PM   #1
FastMatt
Drives: Raven FR-S
2013 FRS 6MT - Heavily modified, Beautiful, Edelbrock supercharged
SOLD
Car is beautiful and in great shape, one original owner, clean title in hand, 0 accidents.
Extensive records kept. Car was regularly serviced by ModBargains in Southern California and by Neal at The Racer’s Line in Northern California. Engine oil was changed every 5000 miles or earlier (most recent service performed last month at 68.8k miles) Transmission and differential fluid changes were performed every 20,000 miles (most recently at 59.5k miles, brake fluid replaced during that service as well).
Edelbrock supercharger installed at 55k miles, updated bypass valve installed at 66k miles, unit has performed beautifully. CARB sticker is on the underside of the hood.
Car was dyno tuned in-person by the one and only Zach at CSG. Tuning maps were created for 91 pump gas and E85 flex fuel, both with the stock header and with a catless UEL header (Open Flash). Car produces 319 WHP/235 Tq with E60+ FF and 292 WHP/217 Tq on 91 pump gas. Power production is very smooth and the setup is rock solid with a Perrin oil cooler.
Forum verification sign.
FastMatt is offline
Old 12-21-2020, 12:13 AM   #2
guruwu
guruwu's Avatar
Drives:
Beautiful car, GLWS
guruwu is offline
Old 12-23-2020, 11:15 AM   #3
TheGimster
Drives: 11 STI 650whp(sold); 19 WRX 402whp
Not only is this a very good build, but this is one of the best For Sale posts I've ever come across. Best of luck getting that much though... I've been monitoring this forum for a really long time, and I think the vehicle will be with you for quite awhile at that list price - just my $0.02.
GLWS!
TheGimster is offline
Old 12-23-2020, 04:52 PM   #4
FastMatt
Drives: Raven FR-S
FastMatt is offline
Old 01-15-2021, 02:37 PM   #5
FastMatt
Drives: Raven FR-S
FastMatt is offline
The Following User Says Thank You to FastMatt For This Useful Post:
dhuang (02-06-2021)
Old 02-03-2021, 02:51 PM   #6
FastMatt
Drives: Raven FR-S
sold
FastMatt is offline
Old 02-27-2021, 01:57 PM   #7
Jansen
Drives: Beout
Did it really sell for 15k?
Jansen is offline
Old 02-28-2021, 08:34 PM   #8
TheGimster
Most boosted twins sell for mid-high teens. Don't ever spend the money to boost one unless you're 100% sure gonna keep it lol. Not a cheap endeavor and you get a measly 10%-20% of those costs back if you sell.
Old 03-01-2021, 03:02 PM   #9
FastMatt
Drives: Raven FR-S
Car was recently listed for auction; however, the auction winner didn't follow through on their end and the car has been released for sale.
So here is a chance to buy this car if you were previously interested but missed the opportunity.
FastMatt is offline
Old 03-02-2021, 04:06 AM   #10
Jansen
Drives: Beout
Car is a beauty.but too bad my dumb ass dont know much about car.lol
It just sound expensive to maintain for a daily.
Jansen is offline
Old 03-02-2021, 04:44 AM   #11
Jansen
Drives: Beout
Can someone explain this like im 5 “Car will need to be flashed with a flex fuel tune before running E85.” Thank you
Jansen is offline
Old 03-02-2021, 12:26 PM   #12
FastMatt
Drives: Raven FR-S
This car is an expensive to maintain as any other car, the maintenance fundamentals are the same.
Regarding your second question, when the car is tuned/dynotuned for a specific type or grade of gas, the settings are saved as a tune file. This process can be performed to optimize performance based on any changes made to the engine, exhaust system, gas, etc. Flashing the tune means loading a different tuning file or "map" into the ECU. Currently the car is running a 91 pump gas tune, allowing it to pass smog as the rear O2 sensor needs to be read in order to pass. If you're fine with sticking to 91, you can leave the car alone and enjoy the car as-is. If you want to take advantage of E85/flex fuel and the extra power that it can unlock, the car will need to be flashed with the flex fuel tune before filling up with an ethanol-based fuel. In this case, flashing the ECU is done by essentially uploading the optimized tune file into the ECU using an Ecutek computer/cable interface.
FastMatt is offline
Old 03-02-2021, 03:23 PM   #13
Jansen
Drives: Beout
Thank you for the aswer!it says “Car has been setup for drifting (hence the PBM super angle kit)” i just need a daily not track/drift.would it be easy to setup for daily?what do i need to change?sorry for a lot of noob questions!thank you
Jansen is offline
Old 03-02-2021, 03:39 PM   #14
FastMatt
Drives: Raven FR-S
It was my daily without any issue. The only thing that's somewhat aggressive with how it's currently setup is the front camber. If you have the suspension re-aligned to remove the front camber, which is currently set to -5 degrees, it would be better for daily driving. For added comfort, the dampers can be set softer (knob adjustment on the top of the strut) and the ride height can be set higher using the airlift controller in the car.
FastMatt is offline
(CA) - 2013 Asphalt Scion FR-S Edelbrock Supercharged itsibarra Cars for Sale/Trade 12 10-10-2018 03:48 AM
2015 Halo FR-S, 450whp, heavily modified, 25k miles, St. Louis, MO $23,500 TRACE_on Cars for Sale/Trade 13 09-27-2018 03:39 PM
2013 Scion FR-S 6MT Edelbrock Supercharged 32k miles, SOLD chapmans Cars for Sale/Trade 3 04-04-2018 04:14 PM
Advice before purchasing heavily modified 86 Insane Scion FR-S / Toyota 86 GT86 General Forum 90 04-13-2017 07:43 AM
FS: Vortech Supercharged 2013 Scion FRS "10 Series" - Heavily Modified (Walnut, CA) NRG x FRS Cars for Sale/Trade 17 10-30-2015 10:52 PM
