Old 12-16-2020, 10:42 AM   #1
sirelboe
sirelboe's Avatar
Drives: 2013 BRZ Lmtd
HID light ballast?
hey guys i'm trying to replace the ballast on these HiD lights that came with my used 2013 BRZ.
anyone know where to buy, which compatible model to get?
KDLT003 koito?
sirelboe is offline   Reply With Quote
Old 12-17-2020, 02:20 AM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Those are OEM Ballasts.
You would probably be better off trying to source a whole used headlight than trying to get just the ballast. They go for ~300 for a pair these days for headlights
EndlessAzure is offline   Reply With Quote
Old 12-17-2020, 04:11 PM   #3
sirelboe
sirelboe's Avatar
i can actually find the used ballast for around $30ea but i want new.. not trying to face this issue again in a few months. i just need a compatible model that would fit and be same voltages. we're also in a deep freeze rn on the upper east coast so i'm sure that stresses it harder on cold startup. i think that's what caused it to recently start acting up.
Old 12-18-2020, 09:50 AM   #4
sirelboe
sirelboe's Avatar
can anyone confirm if this will work? says replaces Denso / Koito Models: KDLT003 / DDLT003:
https://www.amazon.com/gp/aw/d/B01N4...SEQWAA1I&psc=1
or this one actually says on the sticker:
https://www.amazon.com/gp/aw/d/B07J5...0RNYCGE8&psc=1
Old 12-19-2020, 10:26 AM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
it would require modification, as the oem ballast doesn't use the same input wire type:
https://www.ebay.com/itm/FACTORY-OEM...temCondition=4
Old 01-06-2021, 11:55 AM   #6
sato
sato's Avatar
Drives: Dodge Patitas
Late reply, but check with TRS if they have some. Ask them about photos/connections. Hope you solved your issue.
Old 01-07-2021, 05:06 AM   #7
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
This is your opportunity to upgrade your hid bulbs & ballast to other good manufacturers like Diode Dynamics, GTR Lighting, etc. that have made great advances in lighting tech. I'd stay away from Amazon unless you're getting reputable big brands (Philips, Bosch, Osram, etc.).
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
OEM BALLAST 6spd Want-To-Buy Requests 0 06-06-2016 08:03 AM
WTB: OEM BRZ HID Ballast Cheeto Want-To-Buy Requests 1 02-17-2016 01:12 PM
D4S Ballast and Bulb Andrew025 Exterior Parts (Aero, Lighting, Etc.) 0 09-02-2014 12:36 PM
Wtb: 55w h11 ballast Tr1huynh Want-To-Buy Requests 0 03-05-2014 07:40 PM
HID slim ballast Kit for 86 ? TRD_86 Cosmetic Modification (Interior/Exterior/Lighting) 21 08-02-2012 03:50 AM
