Old 12-14-2020, 04:46 PM   #1
SCFD
Rear Sway Bar Delete
I'm new to the platform and need a bit of help deciding how to setup my car for next year as a dual purpose SCCA D Street and time attack car.
Rules allow for 1 bar change so my original plan was to pick up a Hotchkis FSB and run it on the softest setting. However, I recently started leaning towards deleting the RSB after encountering inside rear tire spin a few times.
As a stock car, I feel like the BRZ already has pretty good roll resistance where I might be able to get away with removing the RSB. Any feedback on how the car performs with either setup (bigger front bar vs deleting rear bar) would be appreciated.
Planned mods:
OEM crash bolts, 0 toe all around
225/45R17 200TW tires
SCFD is offline   Reply With Quote
Old 12-14-2020, 05:36 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Removing the rear is fine I removed mine in winter to help with snow and ice traction. Didn't notice too much until I put the 200tw tires back on
The Following User Says Thank You to DarkPira7e For This Useful Post:
SCFD (12-14-2020)
Old 12-15-2020, 09:30 AM   #3
strat61caster
strat61caster's Avatar
Front stiffness helps the car transition more quickly in slaloms and a little help in terms of reducing camber loss due to body roll in steady state. You can try no rear, I have, but I don't think it helps as much as a stiffer front.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
Racecomp Engineering (12-15-2020), SCFD (12-15-2020), ZDan (12-15-2020)
Old 12-15-2020, 09:49 AM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
For a street car, stiffness is OK. For track, stock suspension is way too soft. I'd go the stiffer front-bar route and keep rear bar. And anything you can do to get more front camber would be for the best... I don't think just camber bolts will get you where you wanna be. CAn you run offset top mounts or camber plates?
SCFD (12-15-2020)
Old 12-15-2020, 09:54 AM   #5
ML
ML's Avatar
Drives: 13 White MT FR-S
shits gonna push (understeer)
Old 12-15-2020, 09:58 AM   #6
steverife
Drives: 2016 Scion FRS
Frankly, rear bar delete on a stock sprung car sounds awful.
You won't be able to reduce camber loss and you are giving up overall roll stiffness, both of which are at a premium in Street. Additionally, I think you would introduce some nanny interference weirdness.
With that said, it is free to try (outside your time to disconnect/reconnect and your opportunity to try/learn something else during those runs), so go for it.
steverife is offline   Reply With Quote
The Following User Says Thank You to steverife For This Useful Post:
SCFD (12-15-2020)
Old 12-15-2020, 10:08 AM   #7
norcalpb
norcalpb's Avatar
I’m curious about this, aren’t the trailing arms responsible for holding camber steady in the rear? I’ve always been under the impression it was just macpherson that had camber loss problems.
Old 12-15-2020, 10:11 AM   #8
steverife
I was speaking to camber loss at the front of the car.
You are allowed one bar change, so by focusing on the rear bar, you are giving up the opportunity to run a larger front bar to minimize camber loss up front.
Old 12-15-2020, 10:19 AM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
Also note that by reducing rear roll stiffness, you're going to get more roll at the rear *and at the front*. Since it sounds like you're gonna be very front-camber-limited, that's not so good. Much better to INcrease front roll stiffness which will reduce front camber loss.
FWIW I've never had serious inside rear wheelspin issues at the track with ~60% stiffer lowering springs and stock swaybars, on RE71Rs. I do get some rear wheelspin out of some lower-speed 2nd gear corners but always both rears.
SCFD (12-15-2020)
Old 12-15-2020, 11:46 AM   #10
strat61caster
Inside rear wheelspin on Street class ax setup sounds like a lead foot overwhelming the torsen, won't be able to do much to fix that without going up to STX and getting a clutch type diff. You'll have to change your drive style. That being said unhooking the rear bar is free so just go try it before buying a front bar and see if you like it.
ineedyourdiddly
Old 12-15-2020, 12:38 PM   #11
SCFD
Thanks for all the feedback. This reminded me of a setup I previously ran on a FWD car without a front bar. The car was sloppy even with quite a bit of toe-out and heavy springs (suspension frequency of ~2.2Hz).
I think running no rear bar on the BRZ will probably hurt more than help.
The Following User Says Thank You to SCFD For This Useful Post:
DarkPira7e (12-15-2020)
Old 12-15-2020, 12:43 PM   #12
norcalpb
norcalpb's Avatar
Oops sorry, misread that!
FS: Whiteline Rear sway bar endlinks, New Whiteline rear swaybar mount braces e1_griego Brakes, Suspension, Chassis 1 02-15-2017 12:00 PM
WRX rear sway bar: good front sway bar combo? LerpK Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 11-11-2016 06:02 PM
<FS> Perrin 25mm rear sway, Radium front strut, Cusco rear strut bar mav1178 Brakes, Suspension, Chassis 2 07-21-2016 05:49 PM
WTB: Rear sway end links or sway bar with endlinks JoeBoxer Want-To-Buy Requests 1 08-03-2015 01:20 PM
gt 86 rear sway bar Scottyp Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 04-22-2015 03:29 PM
