Old 12-04-2020, 06:57 PM   #1
cat94
Drives: '17 86
Interior Door Panel Fitment Issues
Hello,
For those that have removed the interior door panel of your cars, did you have any fitment issues when putting the panel back on? My drivers side sits completely flush all around (as did the passenger side before I removed it). Now the passenger side has a substantial gap around the entire perimeter.
I'm sure that all 8 retaining clips snapped into place... did I do something wrong?
I'm thinking that either (1) I "bent" the panel when removing it, or (2) the retaining clips wore out when I first removed the panel. If (2) is the case, will replacing the clips fix the fitment? (it was a lot easier to remove the panel a second time, so I'm leaning towards this theory)
Appreciate any advice
cat94 is offline   Reply With Quote
Old 12-04-2020, 11:01 PM   #2
Fit.
The word is fit.
You do not add 'ment to the end of it.
It is just FIT.
"did you have any fit issues"
A fitment is a fixed item of furniture or piece of equipment, especially in a house it is not a replacement for fit.
Old 12-05-2020, 01:08 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
iirc, hanging the panel off the top edge can sometimes be a touch tricky to get everything to line up at first.
i'd just pull it and try again.
Old 12-05-2020, 01:35 AM   #4
cat94
Drives: '17 86
Fit.
The word is fit.
It is just FIT.
Fit! Got it
Originally Posted by beltax90 View Post
never had problems taking on and off my door panels and there being any gaps. But have always kept in mind to make sure all pop clips are there and intact.
what helped me earlier on to make sure each clip was popped properly back in was to take small pieces of masking tape and stick them on the opposite side of where each clip should be. that way i'd know which exact spots to PUNCH..er I mean, pop back into place.
also making sure the top edge of the panel is hanging properly off of the top of the door? making sure wires aren't in the way? what were you doing that required you to take off your door cards?
I did check each clip and counted the clicks as they snapped in. When the door was hanging, everything seemed to line up with the faint marks on the soft rubber on each side. As for wires, there's just the one to the window/lock buttons and I'm pretty sure they well out of the way.. although I could be wrong. Will try again with your tape trick tomorrow.
I was switching out the chrome door handles for black ones
It seems like everything is lined up since all the clips snapped in place. I tried several times on & off but the gap was there every time...
Also, I may have overexaggerated the amount of gap I'm seeing. It's finger 1-2 finger nails worth of space. But the driver side is totally flush against the door with 0 gap.
The Following User Says Thank You to cat94 For This Useful Post:
Tcoat (12-05-2020)
Old 12-05-2020, 01:50 AM   #5
soundman98
soundman98's Avatar
triple check that all there's not any rogue fasteners still stuck to the door panel between removal and reinstallation.. they can get in the way of reinstallation and cause a gap nearly the thickness you're describing.
Tcoat (12-05-2020)
Old 12-05-2020, 02:01 AM   #6
cat94
Drives: '17 86
This could be it. This says that 20 retainers are required (I assume for both sides). I counted 8 on the panel...
https://parts.stevenscreektoyota.com...U00302981.html
Old 12-05-2020, 02:04 AM   #7
soundman98
soundman98's Avatar
and in case you need more for the one's that take a hike:
https://www.clipsandfasteners.com
Old 12-05-2020, 02:20 AM   #8
cat94
Drives: '17 86
That was it! popped out the 2 stuck in the door and everything fits like a glove.
Thanks!
The Following 4 Users Say Thank You to cat94 For This Useful Post:
Celica00 (12-07-2020), soundman98 (12-05-2020), Tcoat (12-05-2020), theneptune86 (01-05-2021)
Old 12-05-2020, 10:56 AM   #9
soundman98
soundman98's Avatar
glad to hear the re-fitment went gooder.
The Following 5 Users Say Thank You to soundman98 For This Useful Post:
cat94 (12-05-2020), Celica00 (12-07-2020), Opie (12-30-2020), Tcoat (12-05-2020), theneptune86 (01-05-2021)
Old 12-06-2020, 06:17 PM   #10
cat94
Drives: '17 86
So.. I must have overtightened the door handle screw and stripped the plastic threads because the bottom screw keeps spinning now and won't tighten.
Does anyone know what this part is called? I've been looking at parts diagrams trying to find the part number for a while now without much luck.
Old 12-06-2020, 08:18 PM   #11
soundman98
soundman98's Avatar
i believe these are the same thing. would need to confirm outer dimensions of the square size:
https://www.clipsandfasteners.com/To...e-p/a14271.htm
cat94 (12-07-2020)
Old 12-07-2020, 10:19 AM   #12
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Fit.
The word is fit.
It is just FIT.
This got me rummaging through google a LOT more than it should have. How fitting.
That said... I think I'll still use the word fitment. I thought "fit up" would be okay but that has an entirely different meaning.
How do the pants fit?
How's the fit on those pants?
How's the fitment on those pants?
Do the pants fitment?
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 12-07-2020, 10:41 AM   #13
How do the pants fit? Proper use
How's the fit on those pants? Proper use
How's the fitment on those pants? Why add 'ment?
Do the pants fitment? Still no ment needed
There is only one definition for the word 'fitment'.
People are trying to make a verb by adding 'ment where the word fit is already the verb.
It is bad enough the stance crowd introduced this word but it is rapidly spreading to everything else.
fit·ment
/ˈfitmənt/
nounBritish
noun: fitment; plural noun: fitments
  1. a fixed item of furniture or piece of equipment, especially in a house
Old 12-07-2020, 10:50 AM   #14
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
fit·ment
/ˈfitmənt/
nounBritish
https://en.wiktionary.org/wiki/fitment
Noun
fitment (plural fitments)
  1. (archaic) Something that suits or fits.
This reminds me of irregardless. Which is an archaic form of the word regardless... that happens to mean the exact same thing.
The Following User Says Thank You to Wally86 For This Useful Post:
Tcoat (12-07-2020)
Interior Door Panel Change ImAdopted Cosmetic Modification (Interior/Exterior/Lighting) 2 08-15-2017 10:23 AM
Interior door panel, rear seat belts, and rear seats wrxdrifter Interior Parts (Incl. Lighting) 0 06-17-2016 10:46 AM
GTSpec brace and under body panel fitment firestorm252 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-05-2015 04:17 PM
No interior lights except door panel lights (BRZ) BRZZZZZZZZZZ Issues | Warranty | Recalls / TSB 3 01-05-2015 12:46 AM
Is this what they mean by panel fitment issues? ahquit Issues | Warranty | Recalls / TSB 7 08-21-2012 03:19 PM
