Old 11-27-2020, 10:28 PM   #1
Robcokiwi
Drives: 2017 Toyota 86
Is it worth tuning a stock 86?
Hi. Does anyone have any experience in getting a stock 86 tuned. I would like a bit more power and torque.Was thinking about getting headers and then would have to get a better exhaust but I like the car quiet. So what about just getting it tuned? If you have gone this route did it change things noticeably?
Robcokiwi is offline   Reply With Quote
Old 11-27-2020, 10:31 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
No, nobody has ever tuned the car.
Only option far more torque and power is an LS swap.
The Following 3 Users Say Thank You to x808drifter For This Useful Post:
p1l0t (12-04-2020), Purist (11-27-2020), Tcoat (11-27-2020)
Old 11-27-2020, 10:56 PM   #3
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
^ Be nice.
I bought an OFT and flashed the Stage 1 tune on my basically stock 86 (Perrin intake tube and drop-in HKS filter). I was surprised to feel (and hear, oddly enough) a decent little bump in power. Whether that's "worth it" is highly subjective, but I have this car to play with a little (while remaining a DD), so it was worth it to me as a first step to learning about the car. I'll get a header sometime soon, but in the meantime it's fun to learn how to read data logs and make little tweaks, if that's what you're into.
Cephas is offline   Reply With Quote
The Following 3 Users Say Thank You to Cephas For This Useful Post:
Ash_89 (11-29-2020), humfrz (11-28-2020), Robcokiwi (11-28-2020)
Old 11-27-2020, 10:58 PM   #4
alphasaur
friendly
Drives: 17' 86
You can just do header and stock exhaust with a tune. Ever so slightly louder than stock. Gives a fairly good bump over stock.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
The Following User Says Thank You to alphasaur For This Useful Post:
SP86 (11-30-2020)
Old 11-27-2020, 11:14 PM   #5
Purist
Purist's Avatar
Drives: Subaru BRZ
Catless headers and an OFT tune will transform a stock car, especially if you have access to E85.
The E85 + headers combo is not subjective. It is a double digit increase in both power and torque that you will feel without any doubt whatsoever.
Intakes, filters etc do very little.
Research OFTs very thoroughly. You can get an OFT and flash a tune yourself that will be every bit as good as a dyno tune for what you want.
Is it worth it? Absolutely, when you get bored of your car the way it is.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
The Following 3 Users Say Thank You to Purist For This Useful Post:
alphasaur (11-27-2020), Impureclient (11-28-2020), SP86 (11-30-2020)
Old 11-27-2020, 11:20 PM   #6
HaXx
Drives: jrsc_brz
The tune is probably going to cost what it's going to cost regardless, so you might as well bring some parts to the table before you go in to "get your money's worth" even though ur actually spending more on parts.
Yes, a dynotune on a car off the lot would yield a little power and better driving feel, but you should absolutely get a header, even a oem one and punch the cat. The hks header is good value too. Header and tune is what u do, as I'm sure u know, dont mess around with air filters and intakes
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 11-27-2020, 11:33 PM   #7
Originally Posted by Cephas View Post
^ Be nice.
There is a whole sub forum dedicated to this topic. A few minutes of reading would answer this question.
Robco - I would make sure you work all the gremlins out of your car before you start changing things. It will make other issues much easier to trouble shoot if you get everything working properly first.
Yes a tune is worth it even if totally stock.
jkamelo (01-30-2021), Robcokiwi (11-28-2020), Windycitystig (11-28-2020)
Old 11-28-2020, 12:24 AM   #8
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
this is one of the stickied threads in the engine section.
start here
https://www.ft86club.com/forums/showthread.php?t=81493
The Following User Says Thank You to RToyo86 For This Useful Post:
Old 11-28-2020, 12:58 AM   #9
humfrz
Oh, my -
The car came from the factory already tuned. If you like your car quiet and dependable, I'd suggest you just leave it alone.
The Following 3 Users Say Thank You to humfrz For This Useful Post:
jcw99 (11-28-2020), LimitedSlip (11-28-2020), suzyj (11-28-2020)
Old 11-28-2020, 02:51 AM   #10
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Oh, my -
Let Zach at Counter Space Garage do a 93 octane and E85 tune. So far I'm very happy with the results I got with no other modifications other than a higher-flow, ethanol-ready fuel pump. Butt Dyno says I've picked up about 18 HP and maybe 15 lb./ft. of torque.
I'll have to schedule another Dyno run here in the next few weeks to verify. But this is just the beginning. I've got more plans for this build.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
humfrz (11-28-2020)
Old 11-28-2020, 02:57 AM   #11
humfrz
I'd have to see your butt dyno print out -
BigHugeFatGuy (12-01-2020), soundman98 (11-28-2020), Tcoat (11-28-2020)
Old 11-28-2020, 03:14 AM   #12
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
The Following 3 Users Say Thank You to FR-S2GT86 For This Useful Post:
jflogerzi (11-28-2020), soundman98 (11-28-2020), Tcoat (11-28-2020)
Old 11-28-2020, 05:37 AM   #13
humfrz
Old 11-28-2020, 06:01 AM   #14
Purist
Purist's Avatar
Drives: Subaru BRZ
Stock fuel pump is ethanol ready and flow is adequate for E85 if na.
Less More
Recaro Sportster CS vs Stock - worth it? JDM4E Cosmetic Modification (Interior/Exterior/Lighting) 30 06-03-2017 08:54 AM
Worth tuning an automatic FRS? Dp3 Scion FR-S / Toyota 86 GT86 General Forum 79 01-19-2017 09:26 AM
Performance shocks with stock springs, worth it ? Sylvain44 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 08-29-2014 03:18 AM
