Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-24-2020, 08:35 PM   #1
salty_91
Yaris GR engine into an 86
I know this is more about fantasies than real things, but what a great match that could be if they planted Yaris 1.6 turbo into the new car?
I only see benefits:
Torque. First of all - torque! 360 nm or so they claim on Yaris;
Weight. Inline 3 engine would be much lighter than boxer 4 even with all turbo stuff on it (hence the better weight distribution, hence improved cornering, etc, etc);
Balance. Since the engine is straight and not flat it would be possible to push it further into wheelbase without interfering with the steering column (center of gravity is not moving forward, or probably even gets more inward);
Cost. No additional development needed - they've got their own engine, just need to place it;
• Perfect fitment into model line - junior Supra has bigger displacement 4 cylinder.
Now for probable cons:
• Boxer engine has lower cog than inline one (which I think is absolutely canceled out by weight difference)
• 3 cylinder turbo noise (no good, but fa20 was also not a music to ears)
That's it. Your thoughts?
salty_91 is offline   Reply With Quote
The Following User Says Thank You to salty_91 For This Useful Post:
NoGoodNames (03-17-2026)
Old 11-25-2020, 12:13 AM   #2
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Id rather have the 2.4l
The Following 8 Users Say Thank You to Irace86.2.0 For This Useful Post:
8inchAzN (11-25-2020), Bristecom (01-21-2021), DarkPira7e (11-25-2020), ElijahF (11-26-2020), jflogerzi (11-25-2020), Red-86 (11-26-2020), sato (11-26-2020), Tcoat (11-25-2020)
Old 11-25-2020, 12:28 AM   #3
Sasquachulator
Pavement Grey
It'll be an interesting swap for sure.
motor looks pretty tall compared to the boxer though, might take a bit to fit.
Just need someone with boatloads of money to do it.
Old 11-25-2020, 05:01 AM   #4
salty_91
Someone like Toyota themself
I mean n/a is great, and it pleases me to think I've got Porsche like flat engine under the bonnet, but some extra torque (and a bit more power) would breathe life into the car (and boost their sales by the way).
Old 11-25-2020, 05:55 AM   #5
You mean like the 2.4?
I highly doubt that they care about boosting sales. These are not profit margin cars and are a planned limited run.
The Following 7 Users Say Thank You to Tcoat For This Useful Post:
Dadhawk (11-25-2020), Irace86.2.0 (11-25-2020), marky (12-08-2020), PulsarBeeerz (11-25-2020), spike021 (11-26-2020), strat61caster (11-29-2020), theneptune86 (01-21-2021)
Old 11-25-2020, 09:31 AM   #6
StE92ve
StE92ve's Avatar
Drives: 2014 Mazda CX-5
I'm not in the market for a turbo. If I was, there are other vehicles I might consider.
StE92ve is offline   Reply With Quote
Old 11-25-2020, 09:44 AM   #7
Less weight won't change CG, at least not it's height. Moving any weight up (even an ounce) will move the CG up even if the weight stays the same. Lighter weight higher up is likely to also move the CG up even if you keep it the same front to back.
Tcoat (11-25-2020)
Old 11-25-2020, 10:31 AM   #8
salty_91
Yes, I agree the engine CG will move higher, but I don't think it will change things substantially for the whole car since it's just 3 cylinder not even 4. There's a bunch of rwd cars with longitudinally mounted inline engines that have great handling, I don't see why things should go wrong for 86.
"The unit is in fact the largest-capacity and most powerful three-cylinder engine currently in production, yet it is also the smallest and lightest 1.6 turbo unit." that's what they write on it.
Old 11-25-2020, 10:35 AM   #9
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
"The unit is in fact the largest-capacity and most powerful three-cylinder engine currently in production, yet it is also the smallest and lightest 1.6 turbo unit. Its maximum power output is 261 DIN hp/192 kW at 6,500 rpm, with maximum torque of 360 Nm delivered from 3,000 to 4,600 rpm – performance on a par with that of a 2.0-litre turbo unit." that's what they write on it.
Off topic... but:
https://www.motorauthority.com/news/...600-horsepower
Not sure on it being light or anything though, but certainly no weakling for a 3 cylinder.
Dzmitry is offline   Reply With Quote
Old 11-25-2020, 11:08 AM   #10
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I'll never own an engine again that has the oil filter hanging off the side!
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
Irace86.2.0 (11-25-2020), Wally86 (01-14-2021)
Old 11-25-2020, 11:30 AM   #11
salty_91
Originally Posted by Dzmitry View Post
Off topic... but:
That's insane but here you go when production budget is not an issue
Dzmitry (11-25-2020)
Old 11-25-2020, 11:51 AM   #12
salty_91
Looks like they don't, but.. why simply not to make a better car having all the ingredients to do so, and not having to sacrifice the balance (most probably it will even get improved)
Old 11-25-2020, 12:07 PM   #13
Dzmitry
Dzmitry's Avatar
Just for a few simple reasons. They want a low CG to say it has a low CG and it does improve handling to a certain extent (how much, I don't know). They also want to keep it N/A for the simple reason that they say it's what it was built to be, and it keep costs down. No matter HOW GOOD any other solution might sound out there, they were NEVER thinking turbo to begin with and it stayed crossed off the list. That makes their final options much more simple in terms of what they could give to the public. They want to be able to tell you that they built it for a certain purpose, and they stuck to that purpose. So that's what we have, and I'm fine with it.
The Following 2 Users Say Thank You to Dzmitry For This Useful Post:
Irace86.2.0 (11-25-2020), Tcoat (11-25-2020)
Old 11-25-2020, 12:14 PM   #14
It is a good engine in a Yaris. That does not mean it is a good engine in everything. If there was one catch all engine that would make every car "better" they wouldn't need so many different options.
engine, swap
Toyota GR Yaris JD001 Other Vehicles & General Automotive Discussions 854 01-18-2024 03:34 PM
Toyota Yaris WRC announced vh_supra26 Other Vehicles & General Automotive Discussions 55 08-12-2017 05:59 AM
Dedicated to those who are in a YARIS! do to them having issues with there FRS/BRZ 86'ing Issues | Warranty | Recalls / TSB 23 09-15-2012 04:57 PM
FR-S vs Yaris/Tercel, yes you read that right regal FR-S / BRZ vs.... 2 08-13-2012 11:43 AM
2012 Toyota Yaris Dark Other Vehicles & General Automotive Discussions 13 10-10-2010 11:57 AM
