Old 11-22-2020, 09:59 AM   #1
gpvecchi
gpvecchi's Avatar
Different kinds of coilovers
I noticed that there are 2 main types, one like Ohlins that can be height adjusting without changing spring preload, and another one like KW that can be height adjusted via spring preload.
What are defects and advantages of both types?
I know that in second type, lowering will reduce excursion.
gpvecchi is offline   Reply With Quote
Old 11-22-2020, 10:31 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The advantage is exactly as you've outlined- being able to control ride height separate from the spring pre-load. I think the only disadvantage to adjusting them separate is that you're intruding more adjustments, which is more complex.
Think of it like buying a rifle without a scope, vs buying a rifle with a scope. Yes, the gun will still shoot and function without a scope. Adding the scope with allow you to dial in your aim properly though, but adds complexity in that it's one more setting you have to adjust.
Adding a scope = Separate pre-load adjustment
The Following User Says Thank You to DarkPira7e For This Useful Post:
gpvecchi (11-23-2020)
Old 11-22-2020, 10:50 AM   #3
new2subaru
Weight Weenie
Drives: 15 FR-S
Check this out.
The Following 6 Users Say Thank You to new2subaru For This Useful Post:
Capt Spaulding (11-23-2020), glhs386 (01-08-2023), gpvecchi (11-23-2020), Ohio Enthusiast (11-22-2020), Plumbus (11-23-2020), Racecomp Engineering (11-22-2020)
Old 11-22-2020, 11:30 AM   #4
marco_mc22
Drives: Toyota 86
In this specific case Ohlins has the separation of preload from ride height because they’re travel limited (as most monotube shocks), and most coilovers with that system suffer from that.
The disadvantage of the spring perch adjustment is what you already know, but in the case of Kw’s which are twintube it’s not a big problem unless you run too much low/high ride heights outside of the range. In both cases you will have other problems before you’re even near of the maximum/minimum.
Other big factor is spring rate, the more you run stiffer springs the less travel problems you will end up with, generally with low spring rates you need as much travel you can get.
marco_mc22 is offline   Reply With Quote
The Following User Says Thank You to marco_mc22 For This Useful Post:
Old 11-22-2020, 12:23 PM   #5
Almost always a cost saving measure that has been marketed as an important feature.
You'll notice most very high end shocks do not have separate ride height and preload.
It can be a good thing to have if you know how to use it and it's designed right, but that is uncommon.
A few more details:
https://www.instagram.com/p/B9J1M8Un..._web_copy_link
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
gpvecchi (11-23-2020), grumpysnapper (11-23-2020), Ohio Enthusiast (11-22-2020)
Old 11-22-2020, 09:38 PM   #6
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Height independent coilovers tend to have shorter shock travel (shorter stroke, less distance until bottoming out).
EndlessAzure is offline   Reply With Quote
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
gpvecchi (11-23-2020), Racecomp Engineering (11-23-2020)
Doors are all kinds of messed up lizbrayan Cosmetic Modification (Interior/Exterior/Lighting) 37 04-22-2016 07:21 PM
What kinds of gains do you expect with E / I and tune? Partial Stall Engine, Exhaust, Transmission 66 05-10-2012 11:56 AM
