| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: 2017 toyota GT 86
Cheap Oil catch can DIY Install
i didnat want to buy the super expensive catch can that people usually buy. Im on a budget and found from reviews that this ebay catch can works just fine. This catch can costs $23.88. better then paying hundreds.
All you need for this install is. 1. Oil catch can $23.88 ebay 2. some hose clamps $5.25 ebay 3. tank mount bracket $14.50 amazon 3. 1/2 and 5/16 heater or fuel hose (you can get this anywhere online or at your local auto parts store) The hardest part of this install in finding where to mount it. i found the perfect spot in the engine bay. I did not even have to drill any holes. in the back of the engine bay near the steering column you will see a rubber grommet remove that and you will have clearance to use a premade hole to mount the brack to. use the existing bolt you see sticking out that a plastic clip is attached to. remove the clip and move the wire out of the way. mount your bracket on that bolt. fish a bolt inside the hole to get it through the other side then just put a nut on the other side. Use this video to see where your hoses need to go. You will need an additional big hose clamp that fits around the catch can to hold it in place. links to products Bracket https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 hose clamps https://www.ebay.com/itm/10pc-Hose-C...72.m2749.l2648 catch can https://www.ebay.com/itm/Red-Aluminu...72.m2749.l2648 [IMG] [/IMG][IMG] [/IMG][IMG] [/IMG]
| Mishimoto Oil catch Can install | hedtrip | DIY (Do-It-Yourself) Guides | 0 | 11-20-2019 09:16 PM |
| Malperformance Catch Can install | sweetfrs | Engine, Exhaust, Transmission | 7 | 02-01-2016 11:06 AM |
| Mishimoto oil catch can install / review | Craig | Engine, Exhaust, Transmission | 0 | 04-11-2014 02:51 PM |
| catch can and install day from 11am to 2pm at my place | stockysnail | Northwest | 1 | 03-16-2014 01:27 AM |
| Cusco catch can install | wbradley | Engine, Exhaust, Transmission | 2 | 01-11-2013 12:11 AM |
