Old 11-17-2020, 08:09 AM   #1
SCFD
Aerodynamic penalty for removing factory muffler
I'm thinking of getting a single exit exhaust and won't be able to fill the gap left behind with any type of diffuser or paneling.
Do we know how much of an aerodynamic penalty there is when replacing the factory muffler with anything other than another OE shape/sized muffler?
SCFD is offline   Reply With Quote
Old 11-17-2020, 09:10 AM   #2
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Verus Engineering
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 11-17-2020, 09:28 AM   #3
SCFD
Originally Posted by Westen86 View Post
Verus Engineering
It looks great and I would if I could but the class I want to run will not allow me to have this kind of mod.
Old 11-17-2020, 10:03 AM   #4
Westen86
Purist
Westen86's Avatar
Oh, race rules are involved. Well I can say many many people have ripped off their factory muffler, even racecars. I understand your concern about drag, but I believe the effects are minimal.
Old 11-17-2020, 10:11 AM   #5
SCFD
Right, primarily concerned about drag or if the rear-end starts feeling floaty at certain speeds. At the tracks I've been to so far, I can't see myself going higher than 110mph but I don't know if I'll end up at a higher speed track.
Old 11-17-2020, 11:36 AM   #6
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Could you make a coroplast flap that isn't a diffuser?
dragoontwo is offline   Reply With Quote
Old 11-17-2020, 11:41 AM   #7
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Do they let you cut the rear bumper? A lot of people cut that black plastic section off
Old 11-17-2020, 03:19 PM   #8
SCFD
Decent ideas, but those mods won't be allowed. I think I'll just assume that the weight reduction from a single exit outweighs any aerodynamic drag or lift that might be generated.
The Following 2 Users Say Thank You to SCFD For This Useful Post:
DarkPira7e (11-17-2020), dragoontwo (11-17-2020)
Old 11-18-2020, 12:07 AM   #9
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Ya know, if the rear section of the factory heat shield beneath the trunk broke loose and got lodged against the bottom of the bumper....
Breezio is offline   Reply With Quote
The Following 3 Users Say Thank You to Breezio For This Useful Post:
CSG Mike (11-18-2020), SCFD (11-18-2020), soundman98 (11-18-2020)
Old 11-18-2020, 02:00 AM   #10
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
It’s 6 of one and half a dozen of the other. Sure, there’s a penalty but judging by the trap speeds at the Runoffs, it’s negligible and removing that heavy muffler allows you to better distribute weight were it can benefit you more.
What rules? What class?
PRO86 | WTCC | STL
Old 11-18-2020, 12:11 PM   #11
SCFD
I'm going to be building around SCCA D Street rules but also plan on running OTA, a local time attack series which classes cars based on performance index points for mods.
Old 11-18-2020, 12:39 PM   #12
rice_classic
You can probably accomplish both. The 70mm CSG exhaust gives you 2.75" of exhaust diameter (good) and retains a similar style OEM muffler to fill that gap. Then combine it with a 2.5" over pipe/front pipe combo and that will allow the engine to breathe well.
https://www.counterspacegarage.com/c...tition-exhaust
That may be the droid you're looking for.
PRO86 | WTCC | STL
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
Weight penalty with meaty wheel look StraightOuttaCanadaEh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 09-04-2018 11:09 PM
Stock OEM Factory Muffler - Toyota 86 GT FRS2017 Engine, Exhaust, Transmission 0 04-22-2017 06:03 AM
What is the penalty for . . . ? calieigh Off-Topic Lounge [WARNING: NO POLITICS] 1 02-23-2010 11:54 AM
