Old 11-16-2020, 11:39 AM   #1
platinumEX
Drives: '13 BRZ
how to tell if car was previously tuned for E85??
I bought a BRZ from an insurance auction a few weeks ago. Pretty excited about it. It did come with a few mods already - Tein coilovers, TRD exhaust, header, RPF1s...
A couple times when starting it in cooler weather it took a couple times cranking and sputtering before it would run, which made me wonder if the old owner had it tuned for and was running E85. It was a theft recovery and purchased from an auction - I have no idea who the previous owner was or how to find them. I've only driven it around the block a couple times at this point. Seems to run great when started and pulls harder than I remember my old FR-S but it's been a little while, so it could be wishful thinking.
Is there an easy way to tell if it was tuned for E85?
I have a VAGII tool for my wife's Audi, which also reads generic OBDII codes but not sure what else it could do on non-Audi.
platinumEX is offline   Reply With Quote
Old 11-16-2020, 11:40 AM   #2
Gloonge
Drives: 2013 frs raven
I imagine you would need either a tactrix, ecutek or oft to read the ecu programming.
Or the Toyota computer, can't remember the name of it.
Gloonge is offline   Reply With Quote
Old 11-16-2020, 11:43 AM   #3
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
You have a header, so if it were me, I'd find a tuner to look at it.
Old 11-16-2020, 04:25 PM   #4
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
If you live near the southern border of OH-IO, by WV and KY, I may be able to help you out.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 11-16-2020, 04:56 PM   #5
platinumEX
Drives: '13 BRZ
Thanks guys.
I'm in Columbus but once it's road-ready I'd be willing to drive that way. Thanks man.
Old 11-16-2020, 08:58 PM   #6
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
No problem. PM me if you need to set up a meeting. Maybe we can meet halfway. I've got another owner close by me that I've offered my EcuTek ProECU hardware and software if he decides he needs it.
Always willing to help.
Old 11-17-2020, 12:20 AM   #7
Turdinator
Señor Member
Turdinator's Avatar
If it has a header good chance it has a tune of some sort. E85 has a different smell to gasoline. Start it up and see how it smells? Otherwise some other indicators would be a flex fuel sensor in the engine bay or with the car running pull the cruise control stick back (with cruise turned off) and watch to see if the tacho jumps to 1k, 2k, 3k or 4k rpm. That is really only if it is an ecutek tune, OFT will be harder to determine.
1974 TA22 Celica
2013 86 GT
Old 11-17-2020, 04:59 AM   #8
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Plug in any obd tool and read the outputs ie AFR trims etc
gen3v8 is offline   Reply With Quote
Old 11-17-2020, 07:24 AM   #9
And compare to what? If asking the question he probably doesn't know what stock should be so just reading what is there will be of no help at all.
Old 11-17-2020, 08:06 AM   #10
WNDSRFR
Drives: FR-S,GTI
I agree with the smell test. You can smell the exhaust or just smell the fuel filler hole. If it smells like a bar, it's E85.
Old 11-17-2020, 01:53 PM   #11
DarkSunrise
DarkSunrise's Avatar
Another vote for the smell test. On a cold start you can smell the unburnt fuel in the exhaust. With e85 it has a sweet aroma that’s easy to detect. I’d start it up in the morning and take a few whiffs of the exhaust.
There are also cheap ethanol content test kits available but you need to find a way to siphon some fuel out of the tank or fuel lines.
2022 BRZ Build
2013 FR-S Build
Old 11-17-2020, 08:53 PM   #12
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
AFR will be higher for gas. 14.7ish vs E85's 8.7ish at idle (warmed up) depending on the tune.
Old 11-17-2020, 09:18 PM   #13
platinumEX
Drives: '13 BRZ
Thanks for the tips everyone. Some good ideas. I’ll check everything when I get back to it - it’s in our warehouse at work and I’m home this week working on finishing/framing our basement.
Old 11-18-2020, 04:24 AM   #14
Still need to know what the base was to know if it is higher or lower.
Wrecked BRZ previously leased at Timmons, looking for previous owner to buy keys Sumwon Southern California 2 03-18-2020 12:03 PM
Transmission oil change 2nd time - previously amsoil Mikeez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-07-2017 11:47 PM
Satisfied 86 owners who've previously owned a more powerful car (Evo, STI) Veloist Scion FR-S / Toyota 86 GT86 General Forum 63 08-16-2015 12:22 PM
Questions about Catless Front Pipe (previously Need Clarification thread) JFox Engine, Exhaust, Transmission 14 05-29-2014 11:07 PM
