Old 11-03-2020, 04:12 AM   #1
sumoxo
Drives: red, creta
Toyota 86 airbag
I bought a salvaged Toyota 86 with minor cosmetic damage and only one airbag rupture which was of the steering wheel. I knew I needed to replace the airbag and reset the module. When I sent my https aka ms remoteconnect module to be reset the shipping company lost it so I had to buy a new one. I just received my new one from an 86 which had no airbag rupture. I am told that you need to program new ones to work with your specific car by some, however, others say that is unnecessary and can pretty much be plug and play is this true?
sumoxo is offline   Reply With Quote
Old 11-03-2020, 08:08 PM   #2
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
This is way above my level of knowledge, but I’m sure someone in here will know. Are you planning to keep the car stock or modify it? If it’s going to be mostly a track car maybe you could get a non-airbag wheel?
JesseG is offline   Reply With Quote
Old 11-04-2020, 08:34 PM   #3
sunami88
Drives: 2016 Hot Lava FR-S
I feel like no one in their right mind is going to go near that question with a 10 ft pole, in case an inflator goes off in your face while installing/driving or if you're in an accident later and it fails to deploy, etcetc.
There are just too many variables.
Take it to a reputable shop, maybe even the stealership in this case, and let them deal with it. Safety devices like the air bag are not worth bodging.
sunami88 is offline   Reply With Quote
The Following User Says Thank You to sunami88 For This Useful Post:
Tcoat (11-05-2020)
Old 11-05-2020, 10:28 AM   #4
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
They are plug and play, no programming necessary. Just be sure the part number you are installing is the exact same as what came out. Install with negative cable disconnected.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 11-05-2020, 02:11 PM   #5
sunami88
Well I stand corrected (...probably :P). Just remember to carry the airbag module with the metal case DOWN. Lots of people hold it the other way thinking they'll be safer if it blows with the airbag away from them, but the worry is that it might blow near a bench or the car itself and send the metal case up into your face. Been a while but I'm pretty sure that means you want the Toyota logo facing up.
At least with the METAL CASE DOWN it would just push away from your face and knock your arms back...
Good luck, and really, consider paying someone else to do it...
FS: Toyota 86 (JDM) airbag corry29 Interior Parts (Incl. Lighting) 9 02-01-2019 01:18 AM
TOYOTA 86 AIRBAG 6spd Interior Parts (Incl. Lighting) 9 07-16-2016 03:52 PM
FS: JDM Toyota 86 Airbag Eg0 Interior Parts (Incl. Lighting) 21 10-20-2014 01:07 AM
JDM Toyota 86 Airbag troek Interior Parts (Incl. Lighting) 4 06-08-2014 10:27 PM
FS: Toyota 86 Airbag troek Interior Parts (Incl. Lighting) 18 07-29-2013 08:59 PM
