Gentleman/scholar
Drives: 13 FRS, 89 RX 3dr, 00 gf8, 73 F250,
Bank 2 Valvetrain Noise
After replacing the sound deadening for the B2 side injectors, the sound persists.
This is what I believe to be the “sewing machine” sound when warm, which is addressed by Subaru’s TSB 02-151-14R. It involves the replacement of multiple valvetrain components “to reduce a tapping sound (sometimes described as “a sewing machine type” sound) which may be heard coming from the left-hand (B2) side of the engine when the engine is warm.”; copy/paste directly from the TSB. I have worked on a handful of 2014+ 86s, and haven’t heard this sound in them. I’ve heard it in 13s, but to a greater degree usually. Looking for the noise with a stethoscope didn’t turn up anything exciting, as most of the sound is drowned out by the HPFP. Should add that I recorded this after a 185* warm start, with IATs of about 100*. The sound also disappears after blipping the throttle to about 5 grand, which I have a hunch is due to cooler oil being dumped into the B2 head.
Just glassin
73 F250 CSR 390 4otf in metallic sativa; 89 RX turbo fastback hs 1/2600 never ending project; 00 Impreza L 2.2 with a bazillion miles; 13 FRS Ultimate gokart daily; 16 Impreza sport hatch 2.slow for groceries |
not playing cards
That sounds nasty. I hear a bunch of not-ok valvetrain shit on top of the normal stuff.
#3 | |
Gentleman/scholar
A lot of the noise you hear is the trans too though. It has a prolite flywheel. Lol
Just glassin
#4 | |
not playing cards
#5 | |
Gentleman/scholar
Subaru is a pay to play car.
Just glassin
Gentleman/scholar
Further documentation:
The sound only occurs after a hot start, and usually only after it’s sat long enough to suffer heat soak. This video is after 40 minutes of very hard driving. Lots of pulls to redline, CT spikes of about 213*, IAT spikes upwards of 140*. This leads me to believe that it’s strictly an NVH issue. Especially because the revision includes new valve clearances for the B2 head. If it dies, it dies. I’ll replace the engine in 6 beers time. Lol
Just glassin
pessimistic skeptic
You can try Seafoam. It can ease up the valve train. One 16 oz. bottle. 4 oz. goes to oil, 12 oz. goes to full fuel tank. Replace oil after half tank fuel used. Carbon and sludge build up can increase the valvetrain noise.
not playing cards
Sounds perfect in that clip!
![]() Maybe valve lash is just a touch on the loose side and snugs up as the valve stem expands. I understand that, on this engine, it's preferred to err on the loose side because lash decreases on break-in.
#9 | |
Gentleman/scholar
In this case, it’s literally a design fault on Subaru’s part. The 14+ engines have revised valvetrain geometry to reduce the SOUND. According to any information I can dig up, on top of observations I’ve made when working on these cars, it’s strictly an NVH issue. 2013 FA20s just kinda sound like single jingle KAs, and that’s okay I guess. Lol
Just glassin
#10 | |
Gentleman/scholar
I think the issue is mostly due to the angle at which the rocker acts upon the valve. That, and because the valvetrain component’s CoTE is less than the head, I believe valve lash actually increases with heat. Which would explain why it only happens after heat soak.
Just glassin
#11 | |
pessimistic skeptic
#12 |
Gentleman/scholar
I could imagine it quiets down the injectors and hpfp really well. But The intake ports and internals on my motor are too clean to make any difference. I drive up and down a mountain every day, so it spends a lot of time running port injection at low load which keeps the ports clean, and then a lot of time at high RPMs getting really hot, baking all the sludge out. Lol
Just glassin
#13 |
not playing cards
Brilliant. I questioned that very thing as I typed. Totally agree.
#14 |
Gentleman/scholar
It was a serious mindfuck for me when I accidentally found that out. I was like 16 messing with a Honda, set valvelash on a cold engine, and rechecked valvelash on a warm engine. Chasing an intermittent long cold crank was fun. Lol
Just glassin
| Valvetrain noise | Gixxersixxerman | Engine, Exhaust, Transmission | 23 | 01-05-2021 03:44 PM |
| Setting Timing LH Bank | Doopy81 | Issues | Warranty | Recalls / TSB | 32 | 03-01-2019 05:48 AM |
| Valvetrain chatter on KW SC FRS | nlowell | Issues | Warranty | Recalls / TSB | 4 | 05-03-2015 11:20 AM |
| FS: Ported & Polished Heads with Ferrea +1mm Valves and Valvetrain, Ready to Install | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 8 | 02-21-2015 11:21 AM |
| Syste!m too lean bank 1 | jonbonazza | Issues | Warranty | Recalls / TSB | 55 | 07-05-2014 01:36 AM |
