Old 10-21-2020, 07:43 PM   #1
Trickle Charger
Drives: 2018 86 AT Steel
Would Toyo Celsius be a performance Downgrade in the Summer?
Not a fan of the Michelin Primacy OEM tires. Not much snow here on the coast of British Columbia but the temps hover around 0 celsius with lots of rain, then the summers are great with 30-35. Just wondering about an All Weather as far as flex and grip. I don't care about wear much and I might consider a winter performance for the whole year too.
Anyone have feedback on all weather?
Cheers and TIA
Trickle Charger is offline   Reply With Quote
Old 10-22-2020, 10:10 AM   #2
Racecomp Engineering
No experience with that specific tire, but a performance all-season might be a good fit for you. They're not great in snow but okay in cold weather.
You'll go through a winter tire pretty quick if you run it all summer.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Trickle Charger (10-22-2020)
Old 10-22-2020, 11:37 AM   #3
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
You'd be downgrading in feel with an all weather tire for summer use.
I'd rather run a performance all season in your situation like the pilot AS3+/4 if you only want one tire to run all year round.
The Following User Says Thank You to RToyo86 For This Useful Post:
Changing climate control to Celsius cmihaylov Cosmetic Modification (Interior/Exterior/Lighting) 26 07-02-2021 02:30 AM
Toyo Tires Proxes Sport - New max summer performance tires DarkSideFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-18-2018 05:06 PM
Best Performance Summer Tire under $130? Decep Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 01-09-2018 01:35 PM
Summer Performance Tire Recommendation dattran86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 04-19-2017 11:17 AM
FS: 17" and 16" High Performance Summer Tires, TOYO R1R, GTA 7thgear Canada Classifieds 1 04-09-2015 10:48 AM
