Old 10-15-2020, 12:37 AM   #1
Nigori
Nigori's Avatar
Drives: 2020 Hakone 86
OFT V2
Do you need to keep the OFT plugged in after tunning your car? Or will it lose the tune once you unplug it.
Openflash tablet - https://www.openflashtablet.com/shop/oft-gt86-frs-brz/
Nigori is offline   Reply With Quote
Old 10-15-2020, 12:39 AM   #2
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
You can unplug it after you flash your ECU.
Drifter X is offline   Reply With Quote
Old 10-15-2020, 12:42 AM   #3
Nigori
Nigori's Avatar
[QUOTE=Drifter X;3375920]You can unplug it after you flash your ECU.
And every time you want to change your tune it'll replace the previous tune?
Old 10-15-2020, 12:45 AM   #4
Drifter X
Drifter X's Avatar
Yes every time you decide to flash your ECU again it will overwrite the map that was on it prior.
Old 10-15-2020, 06:04 AM   #5
Sam86
Drives: Toyota 86 GTS
Keep it unplugged unless you buy an OBD2 extension cord with an on off switch.
When your OFT is plugged in, even when the car is off it still draw from your battery and can drain it
Sam86 is offline   Reply With Quote
Old 10-15-2020, 06:07 AM   #6
Sam86
Also good idea to keep it out of sight when your car is parked Incase someone thinks it’s an iPad or gps and try to break into your car to steal it
Old 10-15-2020, 08:08 PM   #7
Nigori
Nigori's Avatar
Thanks for the advice
Old 10-15-2020, 08:09 PM   #8
Nigori
Nigori's Avatar
Aight thanks. And I was wondering do you know what size your quad tips are? I'm planning on getting the TRD Kouki Rear Bumper and that requires me to change my tips.
Old 10-15-2020, 08:12 PM   #9
Drifter X
Drifter X's Avatar
No problem! Unfortunately my TRD kouki didn't come with the quad tips because it's a USDM model....
