Old 10-13-2020, 04:25 AM   #1
mausr
Drives: GT86
Question Parking brake cable clip installation
Hi all,
I had to change the rear wheel bearings and they were so seized that I had to remove the hubs and use a hydraulic shop press.
Now, here comes my problem. I am simply not able to reinstall the clips fixing the parking cable to the splash guard:
The little U-shaped clip should slide into a slot in a tube on the backing plate seating in a groove on the cable. The problem is that irrespectively how I tried to insert the clips (using pliers, trying inserting by hand, using a small hammer, etc.) the end pieces of the clips bite into the wall of the tube and gets stucked:
I have destroyed 6 clips with no luck and I could insert the clips only by removing the small end pieces which is not that secure.
Anyone has experience how to install these clips from hell properly?
mausr is offline   Reply With Quote
Blackvue 750/900 parking mode installation Busybee Cosmetic Modification (Interior/Exterior/Lighting) 6 07-21-2019 02:52 AM
E-Clip brake line issue. Trueweltall Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-08-2018 10:42 AM
Mercedes Style Brake Caliper Cover/Clip Andristo Scion FR-S / Toyota 86 GT86 General Forum 10 01-20-2016 07:13 AM
Parking brake clunk FRiSson Scion FR-S / Toyota 86 GT86 General Forum 4 06-28-2012 12:10 AM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
