Rust bucket enthusiast
Does Compression Ratio Affect Engine Note
I've watched a few cars (Subarus exclusively) change from higher compression ratio to a lower one, but all were accompanied by so many different mods it was tough to tell -
Can anyone say for sure that changing the compression ratio will change how the engine sounds? Just curious as this doesn't seem to be discussed often and I thought it was a neat topic. I would imagine that lowering it would also make the engine tone a little deeper and less zingy. |
Drives: Bone stock
Good topic discussion! Sub'd for info.
Sent from my SM-N960U using Tapatalk |
Señor Member
I can't say for sure as I have not seen the same engine go from high to low or vice versa but my feeling from different engines is higher comp motors are louder
1974 TA22 Celica
2013 86 GT |
It only makes sense, right? My car is having a 10:1 engine put in, but I'm changing literally everything, I had stock exhaust before. I'm hoping that it's a more subdued tone
The Dictater
Drives: '13 Red Scion FRS
I think it does make a difference, but how you increase compression is likely important. Increasing stroke would change the sound in a different way than decreasing combustion chambers size.
As for what it actually does to the tone, I need to think more on that... |
#6 | |
Drives: 2013 FR-S Argento
I imagine it affects how you manage dynamic compression with things like valve timing/overlap, that would likely make a significant difference in how things sound. |
In general, changing the compression ratio is done along with other changes. When lowered it is usually with some sort of forced induction. when raised it usually is for higher octane. Both almost always include a change in the cam. The cam, other than exhaust modification, has the greatest ability to change the engine sound.
Drives: 2017 Toyota 86
Yeah, I don't know. Higher compression sounds like a "louder" thing, but lower compression is usually done to make for a bigger explosion safely, which should also be louder.
Maybe there's a slight difference in sound, but my guess is the sound is more impacted by the shape and size of the exhaust tubing the explosions dump into - like how the same buzzing lips can sound like a trumpet or a tuba depending on which tube is put to those buzzing lips. |
#9 | |
#10 |
Drives: Crapcan
As far as I can remember the tone is a bit sharper. It has been a while since I have bumped compression on an engine and stood there to hear the difference so take that with a grain of salt.
#11 |
Anti stance.
Yes.
#12 |
Drives: Q5 + BRZ + M796
#13 |
#14 |
LMGTFY
Drives: 13 FRS, 91 Miata
Friend went from stock pistons to high comp ones in his D16 build recently.
That was the only change at this point. I noticed only a slight tone change at idle. Slightly more high pitched. VERY slightly. |
| Compression ratio for 500hp turbo build | Hags86 | Forced Induction | 24 | 06-03-2018 01:43 PM |
| Compression Ratio for Supercharged w/ Vortech | Gopherboy6956 | Engine, Exhaust, Transmission | 15 | 12-13-2017 05:14 PM |
| compression ratio | nexusatm | Forced Induction | 38 | 05-13-2016 07:59 AM |
| Porsche Patents a Variable Compression Ratio | Captain Snooze | Other Vehicles & General Automotive Discussions | 7 | 04-30-2015 11:21 PM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 07:23 PM |
