Old 10-05-2020, 05:13 AM   #1
letmethefuqin
Drives: 86
Retrofit BRZ apple carplay into 2014 GT 86
Been searching the forums for information on this and have gotten a little lost
Managed to pick up one of the apple play starlink head units from a BRZ and started to put it into a Australian GT86
While I managed to fit most plugs a few didnt fit so I've left them out for the moment - Just trying to figure out whats still missing etc
When Plugged in, Ive come across the following errors
Headunit does not shut off when car is off/locked - however after 5 mins of idle it seems to turn its self to sleep mode/off
*** Any Idea what causes this?
USB is not reading - I dont believe I have this part plugged into the back of the head unit as the plugs maybe different??
*** Are any of the plugs in the picture related to this?
GPS is not picking up location
Unattached plugs
16 pin plug (8/8) - 1 red wire out of the back of it.
Green Square plug - Circle terminal inside
4 pin plug (2/2) - Possible 1 wire in it, and 2 looped wires (Sub/Reverse camera possiblly - def aftermarket wiring done)
letmethefuqin is offline   Reply With Quote
Old 10-06-2020, 10:38 PM   #2
Bowflex
Drives: Scion FR-S
Any reason why you didn’t just go aftermarket? I don’t think the newer radios are plug and play with the older cars.
Bowflex is offline   Reply With Quote
Old 10-13-2020, 07:50 AM   #3
letmethefuqin
Drives: 86
Got it cheap
And also, I come from an era where modifying cars was about trying something new and doing something to make it your own
no hate, but a lot of car mods these days run the same 3 styles, originality doesn't really exist in my country that much like it use to
Old 10-14-2020, 04:15 PM   #4
Bowflex
Drives: Scion FR-S
Originally Posted by letmethefuqin View Post
Got it cheap
Got it. The newer OEM stereos with carplay usually cost a lot more than the aftermarket alternatives, so I was curious. Hopefully you can get it to work.
KY FS Alpine iLX-007 headunit Apple CarPlay JDMBRZ Audio/Visual, Electronics, Infotainment, NAV 3 01-19-2020 08:52 PM
BRZ apple carplay skips/glitches prizmracer Electronics | Audio | NAV | Infotainment 10 03-28-2019 03:21 PM
FS: Double-Din Sony XAVAX100 Digital Multimedia Receiver (Android Auto/Apple Carplay) rubbercow Audio/Visual, Electronics, Infotainment, NAV 4 08-21-2018 01:41 PM
Apple CarPlay: iOS Vehicle Integration mikeTee Other Vehicles & General Automotive Discussions 46 11-19-2014 01:43 AM
Apple iOS Carplay!!! Visxco Electronics | Audio | NAV | Infotainment 28 07-06-2014 04:19 PM
