Old 10-04-2020, 12:03 PM   #1
ThaDonJsuan
Drives: 2020 Subaru BRZ Sport-tech
Soft rattle coming from right side (passengar door?)
Hi all,
I just started hearing a soft rattle noise coming from the passenger side area (seems like the passenger door) when driving over rough parts of the road. I took everything out of the car to see if I could identify the issue - but no luck. I have no idea what it could be.
Has anyone else had any soft rattle issue coming from the passenger side when driving over rough parts of the road?
ThaDonJsuan is offline   Reply With Quote
Old 10-05-2020, 05:28 AM   #2
SUSPECT_BRZ
SUSPECT_BRZ's Avatar
Drives: 2020 Subaru BRZ TS
Most likely suspension related based on your description of the issue. I'm guessing a ball joint is starting to wear out.
SUSPECT_BRZ is offline   Reply With Quote
Old 10-05-2020, 06:11 AM   #3
Check your passenger A pillar. My FRS had a light rattle from what I assume was an airbag wire inside the interior cover. Took me weeks to track it down. Warmed the plastic up a bit with a hairdryer and gave it a whack on the side with the palm of my hand and it went away.
Old 10-07-2020, 08:25 PM   #4
Decep
Drives: 2013 FR-S Series 10
buckle in buddy 'cause there's more where that came from. especially when the temperature drops
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 10-07-2020, 09:30 PM   #5
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Check the glove box door. When the noise occurs, put your hand on the door or unlatch it. Don't ask me how I know . . .
LimitedSlip is offline   Reply With Quote
Old 10-07-2020, 10:13 PM   #6
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
Most likely there's still something under one of the front seats.
Put both seats forward as far as they will go, also tilting the seat backs forward.
Get on the ground, on your knees. From the rear of the seats reach under them, moving your hands along the inside of the seat rails. Feel for any objects which are not part of the car. Check these areas with a bright flashlight as well.
With the seats each all the way forward and also all the way back, feel along the sides of the seats between them and the console, also outer sides of seats.
Use the crevice tool of a canister or shop vac placing it under the seats, searching for any items which your hands could not reach.
Certainly you've already put both seats all the way back, checked under their forward parts with your hands for loose objects.
We often forget some of the things we do inside our vehicles. Some time ago I found an old french fry under the driver's seat, always having thought I never ate in my car.
I am a stickler for not wanting rattles and squeaks. My 6 year old car with 68,000 miles on it does not have any such appreciable noises.
ToySub1946 is offline   Reply With Quote
Old 10-08-2020, 11:04 AM   #7
ThaDonJsuan
Thanks for all the tips/suggestions. Ill get back if I discover the culprit
Rattle sound coming from engine @ 2,500 rpm in 6th Gear FRS2017 Issues | Warranty | Recalls / TSB 8 12-26-2019 07:02 AM
'Fluttering'/soft rattle at speed Symbiont BRZ First-Gen (2012+) — General Topics 35 12-22-2016 01:23 PM
Rattle from driver's side door lock. Mandy Issues | Warranty | Recalls / TSB 0 07-10-2013 08:44 PM
Door Rattle? 636 Issues | Warranty | Recalls / TSB 3 10-17-2012 06:18 PM
Does anyone have a rattle coming from the center dash? Liquidsnake Scion FR-S / Toyota 86 GT86 General Forum 29 09-30-2012 10:09 AM
