Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 10-02-2020, 09:53 AM   #1
ThatYeti
Carbon Trunk Swap?
Picked up a VIS carbon trunk that has a garnish not meant to accommodate the factory backup camera, any chance someone out there has the opposite problem and wants to trade?
ThatYeti is offline   Reply With Quote
Old 10-02-2020, 03:53 PM   #2
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
You could mod it to fit the camera. It’s a small piece.
Ernest72 is offline   Reply With Quote
Old 10-02-2020, 04:42 PM   #3
ThatYeti
Ya, just not excited about the idea of cutting into carbon for fear of cracking it, etc.
Old 10-03-2020, 10:32 AM   #4
HaXx
Drives: jrsc_brz
dremeling carbon is super easy, ive done a shit load of it fitting a carbon fiber belly pan onto a s1000rr. its not nearly as bad as you think its going to be, doesnt fray, doesnt crack, just cut a little square hole to fit the camera. i was petrified before trimming it too, but its underwhelming actually doing it
the chance of someone trading you a carbon fender garnish with a camera cutout for a carbon fender garnish without a camera cutout is non existent.
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 10-03-2020, 12:55 PM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
We did this on my friend's CF trunk. It's not as brittle as you're imagining
Old 10-05-2020, 09:33 AM   #6
ThatYeti
Appreciate the info gents, any advice on doing it? Tape it first? Just use a small drill bit to start?
Old 10-05-2020, 10:49 AM   #7
HaXx
Drives: jrsc_brz
taping a border around the square you want to cut out would be a good start, then use this attachment to cut one side of the square at a time. then test fit the camera and trim a little as needed
Old 10-05-2020, 11:23 AM   #8
ThatYeti
[QUOTE=HaXx;3372987]taping a border around the square you want to cut out would be a good start, then use this attachment to cut one side of the square at a time. then test fit the camera and trim a little as needed
Ok, and so i'd be safer just starting with the cutting wheel as opposed to drilling a bunch of holes around the border then 'punching' it out? Concern is that it'll be a really small hole and using a wheel like that might lead to it being bigger than needed.
Old 10-05-2020, 09:42 PM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
ALWAYS start smaller. and test 4x's as frequently as you think you need to.
when making cutout's, i usually alternate between a fiber-reinforced cutoff wheel for extremely rough shaping, and these for the more precise shaping:
https://www.dremel.com/en_US/product...93-carving-bit
https://www.dremel.com/en_US/product...94-carving-bit
when getting within 1/4" of where it needs to be, i'll shift from power tools to hand tools like sandpaper/files to get the final depth. i've found it's much easier to control without going over to easily.
and test fit often!
Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? 07stealth350z DIY (Do-It-Yourself) Guides 8 08-27-2020 03:27 PM
Carbon Fiber Trunk Swap WhiteTigerX125 Cosmetic Modification (Interior/Exterior/Lighting) 4 02-20-2018 01:52 PM
Trunk Swap (My trunk w/ Limited spoiler to non wing) SWP Kuujo Southern California 4 09-18-2015 01:34 PM
does anyone want to swap his/her wingless trunk with my winged trunk ? (hot lava) hendryhendry Southern California 9 06-03-2013 05:47 PM
WTB/WTT : black brz trunk spoiler or trunk swap ph0en1xtk Exterior Parts (Aero, Lighting, Etc.) 1 03-19-2013 11:03 AM
