Old 10-01-2020, 03:17 AM   #1
ZionsWrath
Thanks
ZionsWrath's Avatar
Tire help for DD please
I am DD a 2015 Mazda 3 sToruing
OEM size is 215/45/18 on 7"
I switched to 16x7 and running 225/55/16 as I like the ride quality and fat tire look
I need a summer tire/"performance" tire that fits on my 16x7, I am open to other sizes
I am currently running BFGoodrich GForce Sport Comp 2. I am happy with their performance so if I can't find anything else I will just buy them again.
I purchased these 3 years ago as it was the only thing decent in this size on Tire Rack. I replace my summers every 3 years, and I just got 3 punctures in one of them so I'm in the market now...
You guys here are very knowledgeable that's why I'm posting here
Old 10-01-2020, 06:18 AM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
Why summer instead of all-seasons? Surely you'd like the option to be able to drive this car in snow, ice, cold, etc. should you have to, right?
BFG GForce Sport Comp 2 A/S Plus looks like a good choice. General GMax AS-05 are also very good for less $$$
https://www.tirerack.com/tires/tests...y.jsp?ttid=253
*IF* warmer-weather performance is so uber-important, *and* you *know* no one will have to drive the car in cold/snow/ice/etc, *and* you need to get 30k, 40k+ out of a set of tires then maybe a Ultra-High Performance summer tire is indeed what you want. In which case BFG Gforce Sport Comp 2 is your only good choice in that size. But it is lacking a bit in wet grip vs. others in that class:
https://www.tirerack.com/tires/tests...y.jsp?ttid=235
But in NY, why would you *need* summer tires *now*?
You might consider UHP all-seasons. For sure you could get tires with better performance in the wet. Which for a street car, for me, is the metric to go by. In addition to snow performance if you might have to drive in snow...
Regarding size, there are a lot more higher-performance tire options in 225/50-16 and 205/55-16 that would fit 16x7, but those sizes are a bit smaller in diameter than OEM for '15 Mazda3 (too bad they deviated from "normal" 25" diameter IMO!), so if not lowered it might look a little funny...
Old 10-01-2020, 01:23 PM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
All seasons don't work for me, i damage them from cornering.
I am the only one driving and I have a winter set.
Mileage not really an issue, i probably put 20k over 3 "summers" on a set. I have the OEM 18s with all seasons as backup/spare
I would have consider 4s if it was available. Maybe I should get 17s....
Old 10-01-2020, 01:55 PM   #4
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
What does your alignment look like?
dragoontwo is offline   Reply With Quote
Old 10-01-2020, 02:01 PM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
On the street, in a (stock?) '15 Mazda3? Ha-ha, OK!
I bet you could use some front camber! In any case IMO at this point you may as well skip UHP summers (which I chewed up my fair share of sets of before sticking strictly to EP category, sometimes MP).
If you want performance street tires that will stand up to hard cornering on a front-heavy fwd car with 16x7 wheels, I'd go 225/50-16 Max Perf (Conti ECS) or Extreme Perf (RT660, ZIII, etc).
Maybe 235/45-17 on 17x8 or 8.5?
Old 10-01-2020, 02:57 PM   #6
TunaNoCrust
TunaNoCrust's Avatar
Drives: 86, 981S, RX8, 2500HD, GenesisV8
I run Yokohama V105 on my DD during the summer and had on the GForce Comp2 A/S before....I would rather run my Blizzaks in the summer than get the Comp2 tires again. The V105 beat them out in every single aspect. The V105 have great dry grip, exceptional wet grip, wear well for 240 treadwear, quiet, and were cheaper. I think Yokohama's new version is the V601?
TunaNoCrust is offline   Reply With Quote
Old 10-06-2020, 06:10 PM   #7
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
My opinion, get the Yokohama Advan Sport V105s (or whatever supersedes them) if they come in the right size. I run those in the summer on my FRS having retired my BFG Sport comp 2 AS to winter duty. The v105s are better across the board.
Old 10-07-2020, 12:05 AM   #8
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I have the Yokohama Fleva V701's on order and will update how they are for DD once I get them.
MS, CSCS, TSAC-F, CPT
Old 10-07-2020, 02:32 PM   #9
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I ran the Comp 2 on my supercharges Yaris and enjoyed them until they started howling at half tread depth.
Currently running Conti Extreme Contact Sport on my FRS and can’t imagine a better tire for my high mileage DD. And the work and last decently when lapping TMP although dedicated track rubber is in the plan for 2021.
Muskoka800 is offline   Reply With Quote
Old 10-14-2020, 10:31 PM   #10
wil5bart
Drives: '16 BRZ
Last month, I bought Hankook V12 Evo2 from 4wheelonline to replace my Continental tires and I noticed a huge improvement. Cornering is impressive and controllable. In wet pavement, they stick far better than I expected.
wil5bart is offline   Reply With Quote
Tire rack giving me a hard time on tire size, so please help! NOI Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-03-2017 06:27 PM
Replace Only 1 Tire? / Spare Tire Question chermo12 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-28-2015 01:44 PM
Tire Blown - Recommended Tire Repair Shop? chermo12 CANADA 3 07-27-2015 11:20 AM
Tire compound vs Tire size Dihudaxia Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-22-2015 10:55 AM
Dai Yoshihara's 2014 Falken Tire/Discount Tire Subaru BRZ FD Reveal SnapOv3st3r BRZ Photos, Videos, Wallpapers, Gallery Forum 62 04-15-2014 02:26 PM
