Drives: 2013 Fr-s
AC condenser replace diy
I made a boo boo recently that resulted in my ac condenser taking a hit. Long story short my jack wasnt correctly seated at the front jacking point and it slipped. Is it an easy replacement?
Sent from my Pixel 4 XL using Tapatalk |
ProCrastinationConsultant
not entirely. the once the condenser is replaced, the system must be re-charged. you can't use the a/c-in-a-can stuff, as it's got hole-fixer gunk that will screw up most properly-running a/c systems.
#3 | |
Drives: 2013 Fr-s
![]() Sent from my Pixel 4 XL using Tapatalk |
#4 | |
don't do that no more.Jack the vehicle up proper next time. It's an easy replacement. Just take your car up to your local AC qualified auto shop and they will fix your car up while you sit in the customer service lounge and drink coffee and read car magazines - OR, iffen you are old, stand outside and smoke cigarettes and tell back in the day stories with the other old coots that shouldn't have been messen wich their car.
Drives: 2020 86
Considering you need to pull down a vacuum to evacuate the system and verify there are no leaks prior to recharging the system with the correct amount of refrigerant, I would say it's more involved than a rad unless the rad is welded to the front subframe on these cars.
6/22/12-2/6/24
Are there any stronger aftermarket AC systems out there? The stock ones are so weak, that on a hot day they barely cool you down.
[QUOTE=Bonburner;3371064]Are there any stronger aftermarket AC systems out there? The stock ones are so weak, that on a hot day they barely cool you down.[/QUOTE]
Well, NOT everyone lives where the temperature gets up to 110 and you're surrounded by forest fires -
Drives: 2020 86
#9 | |
6/22/12-2/6/24
You mean the fan at the front of our car? Is it really that bad? I mean our coolant is so well cooled that I'm doubting it's the fan ...
#10 | |
Rust bucket enthusiast
Regardless, you'll want to have this done at a place that can recover/recharge the A/C refrigerant; if you pull off one of the hoses and there's still pressure, you're going to be breathing some nasty stuff and it coats everything in the area (Guess how I know?) For a regular shop to do it, I would bring the car there with the bumper off, and you can expect to pay about 3 hrs in labor and likely $120-$150 for an A/C recharge, unless shops are charging a lot more these days. Taking everything off yourself will take maybe an hour if you decide you're going to get it all out yourself. But be aware, a lot of technicians don't like starting in the middle of someone else's mess- it's better to bring it to them all together so they can understand how it goes back together, rather than trying to guess. |
#11 | |
Drives: 2013 Fr-s
#12 |
#13 |
Site Moderator
Drives: Stuff
You can rent a manifold set and vacuum pump from several auto parts stores. It's easy to vacuum out a empty system, check for leaks and then fill it through the manifold. Proper oil amt has to be added to replaced components of course.
However since it's no leaking.... you'd have to get it evacuated with proper equipment first if you really care about fixing it. IMO if it's not leaking and the radiator wasn't damaged I'd just ignore it.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#14 |
Drives: Crapcan
Exactly what I was thinking. For the amount of effort it takes to do, run it till it doesn't work. A good amount of the front of the car has to come apart.
| Bad ball joint;possible to just replace balljoint or do I have to replace control arm | kev0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 01-03-2019 03:07 PM |
| Have to replace entire assembly to replace fuel filter? | tobkin | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 08-04-2017 02:26 PM |
| WTB: A/C Condenser | SmireyFase | Want-To-Buy Requests | 1 | 05-16-2017 08:28 PM |
| AC Condenser | MicheleAbbate | Engine, Exhaust, Bolt-Ons | 1 | 05-17-2016 07:11 PM |
| WTB: A/C Condenser | 86_ZN6 | Engine, Exhaust, Bolt-Ons | 13 | 08-21-2013 09:26 AM |
