Old 09-26-2020, 02:30 PM   #1
BRZ_Mobin17
Drives: 2017 Subaru BRZ (silver)
Vortech E85 tune
Is it possible for anyone to send me a E85 tune for the vortech kit, anything so that I can start the car and do some initial data logging?
BRZ_Mobin17 is offline   Reply With Quote
Old 09-26-2020, 07:45 PM   #2
bfrank1972
Drives: 2013 FR-S Argento
Might be some folks with open flash tunes that might be unlocked, most FI folks are ecutek and most tuners lock their ecutek tunes. Contact Vortech and see if you can get a base tune from them?
Edit: they probably don't have an E85 base tune, so nvm the Vortech comment.
Sent from my SM-G965U using Tapatalk
bfrank1972 is offline   Reply With Quote
Old 09-26-2020, 11:52 PM   #3
BRZ_Mobin17
Problem is, it's the weekend so earliest i'll get a response is monday, and that's if i'm lucky. I know there's some openflash E85 users here but it's up to them if they want to share a tune.
Old 09-27-2020, 08:36 PM   #4
jflogerzi
jflogerzi's Avatar
I would just go with ecutek. Look at CSG and Zach Tucker. He will go above and beyond
2013 Series 10 FRS #553
Old 09-27-2020, 10:30 PM   #5
shr133
shr133's Avatar
Drives: 2013 FRS
You will need a fuel map that adds from 0 to 30% more fuel and a timing map that adds from 0 to 5 degrees.. Maybe a cranking map adjustment. The rest of the tune is about the same.
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
shr133 is offline   Reply With Quote
Old 09-28-2020, 05:07 AM   #6
BRZ_Mobin17
Thank you,
I definitely need more fuel because my LTFT jumped from around 2.3 at idle to 23-29 with the vortech kit. As for timing..am I adding that to specific zones or across the board?
I also need to scale my MAF correct?
Thank you again for your response.
vortech supercharger OFT Tune xcuz31 Forced Induction 2 02-01-2017 12:45 PM
Who to tune Vortech setup? pheoxs Forced Induction 18 02-20-2014 02:58 AM
Vortech tune graphs let me know what ya think Frs32907 Forced Induction 10 02-19-2014 10:40 AM
difference between vortech tune and perrin tune? Frs32907 Forced Induction 7 12-05-2013 02:49 PM
Does anybody know if the tune from the vortech is better than the ecutek? Frsexxxy Forced Induction 16 04-08-2013 11:53 AM
