Old 09-18-2020, 10:16 PM   #1
golemslord
Drives: 2014 White FRS
Buy bulbs or change whole kit
Hello,
I have OLM hid kit low beams H11 for a good 4 years now and yesterday one of the bulb died (have tested it and its the bulb not working)
My question is that if its worth to purchase a pair of replacement bulbs such as morimoto ones for 60$ CAD
I dont want to end up getting new bulbs and then the ballast dies soon after
How durable are OLM ballasts if anyone know
Thank you
golemslord is offline   Reply With Quote
Old 09-19-2020, 01:56 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
My experience with hid kits is to just buy new pairs after one dies. As far as OLM eh it's a toss up. It's $60 if it doesn't work out return it. Yeah it's a pain to have the return but eh.
Old 10-07-2020, 04:00 AM   #3
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
You have an FRS, right? Let me quote this from another thread:
Originally Posted by sygfrid View Post
NOTE: this is for the older models pre '17+
Here are the bulbs I've tried:
LOW BEAM:
Right: GTR Lighting Ultra Series 2 LED H11
Left (Top to Bottom):
GTR Lighting Ultra Series 2 LED (950 lux, 9150 lumens/kit, 5450 kelvin)
Diode Dynamics SL1 LED (577 lux, 2455 lumens/kit, 5200 kelvin)
Philips X-Treme Vision Halogen (334 lux, 1586 lumens, 3500 kelvin)
Osram OEM Halogen (284 lux, 1328 lumens, 3425 kelvin)
(the white cut-off line below the left light's coming from the misaligned left fog light)
HIGH BEAM/DRL: Philips Diamond Vision 9005
FOG LAMPS:
Diode Dynamics Luxeon LED, White (600 lumens, 5000 kelvin)
Diode Dynamics SS3 Pro LED, Amber (5200 lumens, 10900 candelas, 109 lux at 10 meters, 3000 kelvin)
As of now, HID is still a bit brighter than LED. HOWEVER, HID has already reached its technological prime & there's not been any new developments. LED, on the other hand, is still evolving & will later on outshine HID. HID's & LED's are compatible with PROJECTORS like our low beams as the projectors have already a set cut-off line to prevent glare. Hence, you can install the brightest bulb you can find & still be street legal (except if you use amber colour or some non-white colour which are usually not legal for street use).
Halogens that produce "white" light are usually tinted blue & are often dimmer than the yellowish 3500k. Primarily, these halogens are just for aesthetics. There are many tests on YouTube & other sites that show this. If you really want a white light that can really illuminate the road, you have to go either LED or HID. However, be careful as only high-quality LED's will create a proper usable beam & will last so much longer than the cheap Amazon ones.
Most of our high beams are reflectors. Though you can switch to HID/LED's, it's usually illegal for street use as they are have a different beam pattern as the reflectors were designed to throw the pattern emitted from halogens.
Sent from my SM-G975W using Tapatalk
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
The Following User Says Thank You to sygfrid For This Useful Post:
smg1138 (11-09-2022)
WTB: Reverse white bulbs + clear switchback front turn signal bulbs Xplicit Canada Classifieds 9 06-12-2016 11:47 AM
FS: OEM side markers + bulbs. OEM turn signal bulbs. akiranakayama Exterior Parts (Aero, Lighting, Etc.) 3 07-29-2015 12:25 PM
LED bulbs 86geek Hawaii 4 03-30-2015 03:12 AM
FS: DRL LEB bulbs vc86 Exterior Parts (Aero, Lighting, Etc.) 6 03-11-2015 12:36 AM
Oil Change Interval Change (Subaru recommended) Flow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 09-10-2014 07:27 PM
