Old 09-17-2020, 01:59 PM   #1
Skyhawk5247
Drives: 2018 BRZ Premium
Clocks
Hi all! So I'm very interested in swapping out the stock head unit for something a bit more android auto friendly. My other issue is that I don't like the clock below the head unit. I think it looks quite cheap. Has anyone gotten rid of it? Maybe even gotten a bigger head unit to get rid of it or something of the sort? I have a stock 2018 BRZ. Thanks!
Sent from my SM-G973U using Tapatalk
Skyhawk5247 is offline   Reply With Quote
Old 09-17-2020, 02:15 PM   #2
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
There's a bunch. Can pop up some good ones on Amazon with high reviews. I saw this earlier and thought it was pretty neat and inexpensive.
https://www.ft86club.com/forums/showthread.php?t=141515
And I love that clock, easiest adjustable clock ever, works like a charm.
Dzmitry is offline   Reply With Quote
The Following User Says Thank You to Dzmitry For This Useful Post:
JesseG (09-24-2020)
Old 09-17-2020, 02:36 PM   #3
Skyhawk5247
I dislike that clock!! Have you seen anyone modify it somehow? I feel like it looks cheap. Especially if the head unit will display time also
Old 09-17-2020, 03:46 PM   #4
JD001
JD001's Avatar
Drives: Subaru BRZ
Cheap!! No kidding, I used to have a similar clock in my Peugeot 205GTi. It's awful, no idea why it's there..
Old 09-17-2020, 03:49 PM   #5
Skyhawk5247
So what did you end up doing?
Old 09-17-2020, 04:20 PM   #6
JD001
JD001's Avatar
Drives: Subaru BRZ
Well, one of the digits lost its elements so I had to get a replacement... took me ages to source one as they turned out to be very rare.. I had to replace it to stay "original".
The Following User Says Thank You to JD001 For This Useful Post:
JesseG (09-24-2020)
Old 09-17-2020, 06:55 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
this is the only alteration that i'm aware of to the clock.
https://www.ft86club.com/forums/showthread.php?t=75181
Spuds (09-17-2020)
Old 09-17-2020, 09:22 PM   #8
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
That is kinda cool. Not very useful, but still cool.
Old 09-17-2020, 09:28 PM   #9
beltax90
beltax90's Avatar
Drives: 2010 corolla
beltax90 is offline   Reply With Quote
The Following 2 Users Say Thank You to beltax90 For This Useful Post:
JD001 (09-18-2020), Spuds (09-17-2020)
Old 09-17-2020, 09:50 PM   #10
Spuds
The Dictater
Spuds's Avatar
Originally Posted by beltax90 View Post
Ok, that's cooler
Old 09-17-2020, 11:56 PM   #11
soundman98
soundman98's Avatar
as someone that had a computer mounted in the dash before it was cool(10 years ago now! i'm old...), i'm well past that fad now. too bright at night(inherent to LCD tech, the backlight must be on to offer an acceptable contrast ratio, but then the backlight bleeds through the 'black' and obliterates night vision), and that's 3/4's of the time i'm driving the car...
Old 09-18-2020, 07:25 AM   #12
Dzmitry
Dzmitry's Avatar
Yeah, from what I've seen online, there really isn't much to be done there. Very few people have coded on an Arduino and displayed other things such as coolant temperature or some type of reading from OBDII. Also, it's just not a very simple thing to manipulate if you go any other route really. Put some cover over it and then you still have your three buttons left over. You pretty much have to take it apart and design and 3D print something else over it.
Old 09-18-2020, 07:33 AM   #13
Ok, that's cooler
I really wanted this when they were first working on it but sadly only works with cars with electronic dual climate controls. They never found a solution for the standard climate controls.
Spuds (09-18-2020)
Old 09-18-2020, 08:20 AM   #14
Just remove it. The weight reduction will be the same as gaining .000001 HP!
Dadhawk (09-18-2020), Dzmitry (09-18-2020), soundman98 (09-18-2020), spike021 (09-24-2020), Spuds (09-18-2020)
Random question about the clocks in our cars. FRSHunter Electronics | Audio | NAV | Infotainment 6 01-16-2014 10:15 PM
