Old 09-09-2020, 03:26 PM   #1
gonzo
Drives: frs
Exclamation FS - 2013 FRS Manual, Slight Mods, 55k miles, Pearl White, SoCal
I'm thinking about selling my 2013 FRS (white) whiteout with 55k in SoCal. Here's the info:
Miles: Single owner. I've never had any issues with the car except nails in tires. It seemed to attract a lot of nails while I lived in San Diego... The car has really nice Michelin super sport tires and I even have a few extra in the garage I'll throw in with the sale.
History: Single owner. The title is clean but during the first month I got the car someone backed into the rear side panel in a parking lot at the gym. I went to the best body shop in San Diego (they focus on exotics) and they matched the paint perfectly. I guarantee you wouldn't be able to spot which side panel was replaced. Other than that, no accidents.
Paint: The paint is in great condition because it's always garaged. I've ONLY hand washed the car myself. I will be claying and polishing before selling. I've never polished nor clayed so there's a ton of clear coat left to easily get the paint back to show room condition. The front bumper has scratches on the bottom and front from rocks and the usual stuff flying up on the freeway after 55k miles. There's a small mark on the left door from when I opened the door too quickly and hit a pole in a parking garage. See photo below for the size of this mark. It's about the size of a small screw driver head.
Maintenance and fluids: I've done all the maintenance and work on this car myself. I replaced the oil at least every 3k miles and used high quality oil (either Toyota brand or better) and filters (Subaru/Toyota brand only). I changed the tranny fluid for Red Line fluid at about 30k. The air filter has been changed numerous times. New battery about 8-12 months ago.
Mods: Nameless 2.5" header back exhaust (sounds beautiful but I also have the stock one), red short shifter to match the interior, winmax W3 brake pads with about 50% life left and resurfaced rotors when installed around 30k miles, rear subframe inserts, tranny mount insert, TRD springs (about half an inch drop on the TRD springs), OpenFlash (can easily run E85 for considerably more power), LED daytime running lights, shark fin antennae.
Clutch throwout bearing replacement: I replaced the clutch throwout bearing at 50k because the original ones were burning up (check the forums). I replaced it with the OEM Toyota replacement throwout bearing that comes with the upgraded grease. I replaced the clutch at the same time since I had the tranny pulled. The clutch looked brand new but I replaced it anyways since I had already bought the OEM clutch. Goes to show how much I baby'd the car while driving. I've never dropped the clutch for a burn out.
Registration: The car was registered this week and had the required emissions related recall performed at Maita Sacramento last month. It's been running perfectly and have had no issues. I will check the oil next time I drain and fill in a couple weeks.
Reason for selling: Got a new job and I'm hesitant to do the commute through LA in this car because it's my baby. The car has a lot of sentimental value to me. But I can't commute 80 miles a day in this car, so I'm planning to get a Tesla with Autopilot
Price: KBB is $14k for "good" condition. Let me know what you're thinking and I'm not in a rush to sell so no low ball offers.
I'll add more items to this post as I think about it. Feel free to ask your questions in this post. Thanks!
Note that I haven't washed the car yet because it's 100 degrees. I will be washing, claying, polishing and waxing the car when it cools down next month. It will be near showroom condition at that point because it has a ton of clear coat left. Will update the pics once I get that done.
gonzo is offline   Reply With Quote
Old 09-09-2020, 03:47 PM   #2
p1l0t
p1l0t's Avatar
Better read the rules
gonzo (09-09-2020)
Old 09-09-2020, 03:47 PM   #3
CaesarTielman
CaesarTielman's Avatar
Was there a recall for your car? And can you post some pictures please? Thank you
CaesarTielman is offline   Reply With Quote
Old 09-09-2020, 04:23 PM   #4
gonzo
Drives: frs
Ok thanks I'll read the rules and update the post.
The Following User Says Thank You to gonzo For This Useful Post:
p1l0t (09-09-2020)
Old 09-09-2020, 04:39 PM   #5
gonzo
Drives: frs
Yes see above in the "registration" paragraph for more details. Had the recall done last month (waited till the last minute so the dealer had experience doing the recall work). They did the recall and I registered the vehicle this week. I plan to check the oil for any deposits when I drain it in the next few weeks to make sure they did the recall work correctly. So far I've put about 1,000 miles on it (drove from Sacramento to LA) and it hasn't had any issues or funny noises. I'm also monitoring the ECU readouts through the OpenFlash unit that may come with the car (or I may part it out separately).
Old 09-13-2020, 06:53 PM   #6
jflogerzi
jflogerzi's Avatar
Also it's your responsibility to get a smog which it won't pass in it's current form
2013 Series 10 FRS #553
[FS] 2013 Subaru BRZ Limited - Pearl White - 6spd Manual - VA blinddub Cars for Sale/Trade 3 01-31-2018 02:28 PM
2013 BRZ Limited. Every Option. Low miles. Pearl White. Manual. WiKKiD Cars for Sale/Trade 5 01-11-2016 11:32 PM
2013 Subaru Brz Limited (Pearl White) Low miles 18k! Very Clean MUST SEE!! WhiteBrz21 Cars for Sale/Trade 3 07-08-2015 07:58 PM
<VIC> .Toyota 86 GTS - Pearl White - 2013 delivered..6 Sp manual os86 Australia Classifieds 8 06-05-2013 01:03 AM
