Old 08-09-2012, 09:11 PM   #1
pinoyplaya
Drives: WRB MT-BRZ LMTD
Cruised in Neutral for 5 miles without loosing speed.
Anyone else noticed that you can pretty much cruise your BRZ into neutral without loosing any speed? I was doing that on a semi flat road and this thing wont stop unless you hit the brakes.
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM
Traded for Black 2013 Camaro 2SS RS
pinoyplaya is offline   Reply With Quote
Old 08-09-2012, 09:17 PM   #2
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I hope my brakes don't fail, I might end up in Soviet Union!
industrial is offline   Reply With Quote
Old 08-09-2012, 09:21 PM   #3
BRZranger
That's cool, but driving in neutral is a bad idea. I used to do it, thinking it was more efficient.
You can't respond to a sudden emergency requiring your to shift into gear and apply throttle. Also you don't really save gas.
Sent from my Galaxy Nexus using Tapatalk 2
BRZranger is offline   Reply With Quote
Old 08-09-2012, 09:25 PM   #4
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I agree with all the safety stuff but if you're gonna be coasting for 5 miles, that's better for fuel economy than staying in gear and essentially engine braking. At the same time, the safety part is more important than a few cents saved at the pumps....
Back on topic, I love how this thing cuts through the air so effortlessly. That's what happens when we have a properly designed car with a great CD. Try doing the same thing in a Miata (Miata is 0.32 I think? Not a huge difference but a Miata shouldn't be that high!)
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 08-09-2012, 09:29 PM   #5
pinoyplaya
I wasnt trying to save gas, I was trying to come to a stop because of a stop light, so shifted to neutral and then cruised to the stop when it went green and I just continued on. lol still in Neutral.
Old 08-09-2012, 09:53 PM   #6
Tomzilla
Tomzilla's Avatar
Drives: '13 Premium MT BRZ
you actually use more gas in neutral than you do cruising in gear.
Tomzilla is offline   Reply With Quote
Old 08-09-2012, 10:00 PM   #7
Thunderchicken
Drives: 2008 STi
Agreed, you burn 1 gallon per 1 hr while in neutral
Thunderchicken is offline   Reply With Quote
Old 08-09-2012, 11:08 PM   #8
WiKKiD
WiKKiD Large Penis
WiKKiD's Avatar
Drives: 2001 Audi TT Quattro "BT 300+Whp"
No it's 5. JK
WiKKiD is offline   Reply With Quote
Old 08-09-2012, 11:15 PM   #9
Stu L Tissimus
Stu L Tissimus's Avatar
Drives: MT GB BRZ Limited
I'm under the impression you won't be using any gas in 6th since it's running in a vacuum, but I'm not an expert.
I am, however, a smart dude, and I'm tempted to say that this road you were on was probably not flat. Friction and rolling resistance team up to make your car slow down no matter what; a slight downhill will counteract that.
すばらしい。いや、スバルしい。
Stu L Tissimus is offline   Reply With Quote
Old 08-09-2012, 11:24 PM   #10
pinoyplaya
Duh, its all about Physics. I'm just overemphasizing the car's drag coefficient.
Old 08-10-2012, 12:54 PM   #11
phattyduck
Drives: '03 WRX Wagon, '89 Camry Alltrac
The engine will only stop using gas when you are in gear, coasting and above about 1200rpm. At that point, it shuts off the fuel injectors. If your foot is on the gas (or the cruise control is on...), then the engine is using gas.
You will use less gas in almost any situation coasting in neutral than in gear. Remember, it takes energy to keep the engine spinning above idle (wasting/using kinetic energy that previously came from gas). Coasting in gear does save your brakes from wear though.
That said, it is safer to keep the car in gear (clutch engaged)... and in many places it is illegal to have the car in neutral while it is moving - not that you will get caught for it.
-Charlie
phattyduck is offline   Reply With Quote
Old 08-10-2012, 01:38 PM   #12
DSPographer
DSPographer's Avatar
Drives: '13 BRZ Lmtd
-Charlie
I have looked up how this works for hyper-miling. You will use less total gas if you coast further in neutral than in gear, followed by less time on the throttle. This is because, since you will normally be above idle RPM when coasting in gear, the friction losses in the engine are greater in that scenario and you don't coast very far. This assumes you start decelerating early enough in both cases that you completely avoid braking. If you are coasting so slowly that the RPM is the same in both cases, then there will be no difference. By the way, partial throttle slow starts are not very efficient. Open throttle acceleration with early shifting is the most efficient. Even up-shifting normally, at about 3500 RPM for the BRZ, is pretty efficient open throttle: since you reach final speed quickly and can then shift to your final gear.
I thought most laws just forbid turning off your car in neutral when coasting (like a poor man's start-stop) if your vehicle loses boost for brakes or steering in that situation.
Anyway, I don't think it's worth it to coast this car in neutral. If you really want to hypermile that way, get a hybrid with start-stop.
DSPographer is offline   Reply With Quote
Old 08-10-2012, 01:55 PM   #13
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Must of had a hell of a tail wind.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 08-10-2012, 02:04 PM   #14
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
I can think of at least one good reason to be coasting in neutral at some point, and that would be for a coast down test to check your aero efficiency. Of course for that, you would want to do it in both directions on the same stretch of road in order to counter any elevation or wind effects.
TheRipler is offline   Reply With Quote
Engine Speed vs Vehicle Speed for 6MT DetroitJake Engine, Exhaust, Transmission 22 04-27-2013 06:56 PM
My car is in and still 1,304 miles away! joshua BRZ First-Gen (2012+) — General Topics 16 06-28-2012 08:02 PM
2500 miles F3dzo Scion FR-S / Toyota 86 GT86 General Forum 13 06-26-2012 09:36 AM
Some Miles White_OUT_FR-S Scion FR-S / Toyota 86 GT86 General Forum 0 06-22-2012 02:00 PM
560 miles later DantKR BRZ First-Gen (2012+) — General Topics 10 06-07-2012 06:03 PM
