Old 08-28-2020, 01:50 PM   #1
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
0W-16 Oil
Has anyone with forced induction tried this new 0W-16 oil developed specifically for boosted, direct injected engines in any of their cars yet?
I'm suspecting it may not work quite right with the VVT system in the FA20/4U-GSE and may cause some codes to start appearing concerning the cam timings.
FR-S2GT86 is offline   Reply With Quote
Old 08-28-2020, 01:58 PM   #2
Tokay444
Anti stance.
Tokay444's Avatar
Why would anyone ever dream of going DOWN in oil weight from the already light weight 0W20?
Old 08-28-2020, 02:35 PM   #3
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
That wonderful cold start protection!
Dzmitry is offline   Reply With Quote
Old 08-28-2020, 02:47 PM   #4
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Honda is beginning to recommend it for their turbocharged engines to combat the oil dilution problems they have been having.
Old 08-28-2020, 04:42 PM   #5
humfrz
I asked Bubba about 0W-16 weight oil and he says you might as well put kerosene in the crankcase.
Old 08-28-2020, 05:00 PM   #6
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Might not be a bad idea of those of us seeing winter conditions. Those -20 cold starts.
Old 08-28-2020, 07:39 PM   #7
glhs386
Drives: 2014 FR-S Monogram
I imagine those engines are specifically engineered to run 0W-16. The FA20 isn't. Using thinner oil than what is recommended by the manufacturer is almost universally a bad idea.
glhs386 is offline   Reply With Quote
Old 08-28-2020, 08:15 PM   #8
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I doubt 4 points would make a difference in a cold start. Not worth the trade-off with risk, since pressure is really important on cold starts where everything is drying out
Old 08-28-2020, 10:29 PM   #9
Halo_2
Drives: 2014 MY15 86 GTS
They are both 0 it would make zero difference in cold start......
Halo_2 is offline   Reply With Quote
Old 08-29-2020, 02:09 PM   #10
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Hold on a sec. Did I read you correctly? Honda are recommending 0-16 to COMBAT oil dilution? So their thinking is adding gasoline to a 0-16 will transform it into a 0-20?
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 08-30-2020, 03:54 PM   #11
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Manufactures want thin oil for better fuel economy. That's all.
I went 5w30 when I added forced induction because all Subaru engines that are forced induction come with 5w30.
If I was tracking the car then I would consider an oil cooler and a heavier grade oil. The GT86Cup manual has the oil listed as ELF HTX 825 10W60. There is an oil cooler option. This is for "stock" cars, so no forced induction, which means less heat and less forces pushing down on those bearings.
https://racing.tgr-europe.com/wp-con...anual_EN-1.pdf
Old 08-30-2020, 06:49 PM   #12
Tokay444
Anti stance.
Tokay444's Avatar
Seems like an oxymoron to go thinner to combat dilution.
Is their reasoning that it’s already as thin as gasoline, so adding more of the same can’t hurt?
Old 09-01-2020, 08:39 AM   #13
Dzmitry
Dzmitry's Avatar
To make myself more clear, though I was mostly joking, it does make a difference. 0W-20 will have a lower viscosity than a 0W-40 oil at startup. In the case of 0W-16 vs 0W-20, the difference is probably quite insignificant to care about, which is why I intended it to be a joke.
Old 09-02-2020, 10:24 PM   #14
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
As far as I understand, 0w-40 will still have lower viscosity at startup than 5w-30? I wonder why most people do 5w-30 and 0w-40 is rarely mentioned.
timurrrr is offline   Reply With Quote
