Old 08-27-2020, 06:47 PM   #1
thekevinvo
Drives: 2014 Scion FRS
Kevin's from salvaged to track FRS
Picked up this previously salvaged title 2014 FRS down in Houston, TX and brought it all the way to Iowa. The car itself is basically stock besides some Stance Suspension coilovers and lower control arms.
Once I got it home, I swapped out the brake lines, fluids, and pads and took it for a spin around Mid-Ohio. Car felt great and was a blast to drive despite having some 500 treadwear all season tires.
Plan to turn the car into my weekend warrior track car that I can drive to and from the track.
Current Mod List:
Verus Engineering UCW Rear Wing
Verus Engineering Composite Front Splitter
FT86SpeedFactory UEL Header
Verus Engineering Hood Louvers
Perrin Oil Cooler
FactionFab FR-Spec Coilovers
Grimmspeed Strut Tower Brace
Grimmspeed Master Cylinder Brace
Hawk HP+ Pads
FactionFab Swept Slot Rotors
Verus Engineering Brake Cooling Kit
Apex EC-7R 17x9 +35mm
Falken Azenis RT660 245/40/17
Rays Gram Lights 57CR Ceramic White Pearl 17x9 +38
Falken Azenis FK510 245/40/17
Remark R1 Spec Titanium Catback Exhaust
Tomei Front Pipe
Motiv Overpipe
Recaro Profi SPG
Buddy Club Super Low Down Seat Rails
Will be trying to document the whole process through my YouTube channel and on here, so if you're interested in following along grab a seat!
thekevinvo is offline   Reply With Quote
Old 09-01-2020, 04:06 PM   #2
thekevinvo
Installed the Perrin Oil Cooler to take care of the high engine oil temps at the track.
Old 09-01-2020, 04:26 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Very nice, though I do think the FRS looks best with the spacer invaders plastic stuff in the front grille.
I painted the white hat on my crash bar using red plastidip and you actually can't tell the difference, I highly recommend if it you're going to leave it out there!
Old 09-01-2020, 10:32 PM   #4
thekevinvo
I actually ended up reinstalling the grille, but I am definitely leaning towards painting the crash beam black if I ever do remove the grille.
Old 09-03-2020, 02:43 PM   #5
thekevinvo
Brake system got an overhaul with some new rotors
Old 09-03-2020, 06:01 PM   #6
Cedric
Cedric's Avatar
When are the JDM headlights coming?
Sent from my iPhone using Tapatalk Pro
Cedric is offline   Reply With Quote
Old 09-04-2020, 03:58 PM   #7
thekevinvo
Lot of money to spend on some fancy lights
Probably won't be installing a set of headlights unless I need to do so for work.
Old 09-08-2020, 04:30 PM   #8
thekevinvo
Finally got rid of some horrendous clunking in my front suspension.
Old 09-08-2020, 07:23 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I find the WL end links come loose easily. I would recommend some blue locktite. I have had to tighten mine twice in the last year, right front is making noise again.
Old 09-10-2020, 03:19 PM   #10
thekevinvo
Appreciate the heads up, I'll have to keep an eye on them.
Old 09-10-2020, 03:19 PM   #11
thekevinvo
Cleaned up the engine bay a little bit with the Grimmspeed Pulley Cover & Hood Struts
Old 09-10-2020, 10:54 PM   #12
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Oh, you're the dude from SubieSpeed and FTSpeed while Thomas is hiding from spark plugs
MS, CSCS, TSAC-F, CPT
Old 09-15-2020, 03:20 PM   #13
thekevinvo
Yes that would be I
It honestly isn't as bad as some people make it.
I'll do another video on my channel going through both sides since people complained.
Old 09-15-2020, 03:20 PM   #14
thekevinvo
Changed out the transmission fluid.
Turning a salvaged title FRS into my track car thekevinvo Scion FR-S / Toyota 86 GT86 General Forum 15 08-28-2020 10:42 AM
Project Rekt - Salvaged BRZ track build statik Member's Car Journals 31 05-16-2016 06:13 PM
WTF is up with all the salvaged cars?! suaveflooder Off-Topic Lounge [WARNING: NO POLITICS] 40 04-09-2014 05:21 PM
Kevin Brown Paul_S Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 03-20-2013 05:39 PM
Kevin's BRZ kgc Member's Car Journals 13 09-19-2012 02:39 PM
