Old 08-25-2020, 10:49 PM   #1
Zaraia
Drives: 2015 Scion Frs
Open flash tablet updated itself...
Long story short, I plugged in my OFT and its been AGES since. It updated and now when I plug it into the car it says "ERROR" "tuning file mismatching, ECU write denied." when I try to add new tunes or anything on Open flash manager, it tells me the tablets never been married to a vehicle. I've put in a support ticket on the OFT website but who knows how long that'll take...ANY help would be greatly appreciated. Thank you all very much in advance!
Zaraia is offline   Reply With Quote
Old 08-25-2020, 11:01 PM   #2
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
I've been disabling my internet connection when using the OFT manager, I got tired of it taking forever to do whatever it was doing. I hope you get your problem fixed!
PetrolioBenzina is offline   Reply With Quote
The Following User Says Thank You to PetrolioBenzina For This Useful Post:
Zaraia (08-25-2020)
Old 08-26-2020, 05:22 PM   #3
elBarto
elBarto's Avatar
Drives: Toyota GT86
Somebody posted this problem in the OFT Support group (FaceBook) and after alot of trail and error this was a working solution (for him). Don't know if it will work for you:
Requires an email to OpenFlash so they can put your serial # on the list (that's the way it sounds anyway)... Here's the email I got:
________________________
Here are the recovery instructions for your OFT Serial number.
This process will erase your OFT, making your device "new" again, and ready for installation on a new car.
First, navigate to "C:/Openflash"
In this directory, look for a FOLDER named as your OFT serial number: E0040100XXXXXXXX
If this folder exists, please connect your OFT and launch Openflash Manager. This *should* successfully recover your OFT. If the folder does not exist, or your OFT is still not working properly, read on.
Please download and install the software found here -> http://www.alientech.to/xnote/sw/pwg...overySetup.exe
Disable any anti virus or firewall/internet connection blocking software
Connect your OFT to your PC via the USB cable,
Launch the software you've downloaded from this email.
Choose "Check Unique File". NOTE: If you see no error messages, and no messages indicating 'this devices is not authorized for recovery", then choose the Recovery button when prompted.
After the software is done, you should witness a success message window.
Choose OK, and then close the software.
Without disconnecting, launch Openflash Manager, and allow the software to finalize any updates as needed.
When the update window disappears, close OpenFlash Manager.
Disconnect your OFT USB cable, and then reconnect.
Re-launch OpenFlash Manager.
After OpenFlash Manager loads again, take a look at your OFT screen. What do you see as the background image?
1. If your image is black/missing, then you'll need to update you template file before the OFT is ready to you.
Download the proper template for your OFT, and go to the Template tab in Openflash manager. Choose the brwose button and select the template file you've downloaded. Select "Start". Allow this operation to finish.
If your OFT background images is "normal" (not a black background - then your OFT should be ready to use.
Lastly, the recovery software will only run successfully one time for any unique (authorized) serial number. Uninstall the recovery software from your PC when finished.
*credit goes to Caleb J Yam*
Link to the FB post
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 08-26-2020, 06:04 PM   #4
PetrolioBenzina
Drives: 17 86
Link to the FB post
One "internet" to the person who can find the correct template file on the OFT site.
Old 08-28-2020, 05:33 PM   #5
elBarto
elBarto's Avatar
Drives: Toyota GT86
There ya go:
OFT Templates
V1 is for the first generation tablet
V2 is for the newer one with the bigger screen
SOLD: Open Flash Tablet, Open Flash Header, Crawford Power Blocks Totemo_Hayai Engine, Exhaust, Bolt-Ons 14 09-15-2019 03:28 AM
Looking at used Open Flash Header. How can I tell if it is the updated v2? BCB75 Engine, Exhaust, Transmission 2 10-17-2017 03:41 PM
My experience with Shiv & his products at Open Flash Tablet / Open Flash Header TouchMyHonda User/Vendor/Sponsor Reviews, Feedback, Comments 5 10-23-2015 10:57 AM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
